new "clink?" from drivetrain...
hey guys, on my 00 F-250 6 spd. i noticed a new sound, i put it in reverse and started letting the clutch out, once it grabbed i heard an odd clink like a u joint or something, pushed the clutch in. kept trying to get it to do the noise again in reverse but it wouldnt so i threw it in 1st and went to take off, CLINK it did it again. tried the same thing as before kept letting the clutch out from a stop and nothing. finally realized that it will make that sound when you first go into reverse from 1st or vice-versa. (like when pulling out of driveway in reverse it will make the noise and when you put it in 1st to take off it will do it again, then not again until you back up.) i crawled under the truck and was twisting the d-shaft with truck in gear engine off and couldnt see any play in the u joint, maybe tranny? o and i could kinda "feel" the clink in the shifter... any help is appreciated, thanks.
Sounds like you grease your slip yoke. You will only be able to feel it from a near or dead stop.
Here's some links (there's a lot out there):
https://www.ford-trucks.com/forums/8...-take-off.html
https://www.ford-trucks.com/forums/7...-how-much.html
mudrat025
35
09-24-2013 01:35 AM
xr75kid
1999 to 2016 Super Duty
05-28-2009 11:00 AM
