Auto. to Manual hub conversion
I have searched everywhere to see what models interchange with my '89 Bronco II front Auto. to Manual hub conversion.
One source was here:
Ford Bronco II bronco II & forum
A friend is throwing out his 03/95 Mazda B2300 pickup truck. It has the manual front hubs. I removed the hubs (that come off once the road wheel is removed), but I'm not sure if they will work on my '89 BII and/or if that is all i need from his truck to complete the swap?
I did check Hollander Interchange, and the results were inconclusive.
Does anyone know if this truck's front hubs will work on my '89?
If NOT, what is the cut off year/make and models of what will fit my '89?
Thanks in advance for any help.
jon
8-)
jon
8-)
on
1 Post
First, you need to identify which front axle you have (click the link) and see if your '89 does indeed have a non-hybrid D35 (all D35 parts, not a D35 case with D28 guts, etc.). If it does, I believe the '95 Mazda truck has the D35 TTB as well (you'd know if it does, it's pretty obvious when you look underneath), in which case the hubs would swap. I'm more inclined to believe your '89 has a D28, though - in which case, there is no way they'd swap. If I were doing a swap on a D35, I'd get the hubs for the conversion kit for a rear Jeep 35 (much stronger) anyhow. More info:
Dana/Spicer Bill Of Material Numbers
Axle Guide For All Trucks
Ford Ranger/Bronco II Automatic To Manual Hub Swap
Warn Jeep hub conversion for the Ford Ranger
TRS Magazine - Ford Ranger Manual Hub Swap
TRS Magazine - Offroad Tech
deepbass
1978 - 1996 Big Bronco
10-12-2012 09:03 PM
meb9796
02-20-2012 02:38 PM
mhorn0817
28
07-01-2011 09:18 PM
