Rear Wheel Wobbling
Old 03-27-2010, 04:53 PM
PU70's Avatar
PU70
PU70 is offline
Rear Wheel Wobbling
The left rear wheel on the 9" has a very slight wobble that you can hardly notice. The wife noticed it when she was following me. I changed the rear wheels left to right and the wobble didnt change. And now it just started to leak. It has one of thoses unit bearings that are sealed. So can a bad bearing cause the wheel to wobble?
Old 03-27-2010, 06:56 PM
johnboy427's Avatar
johnboy427
johnboy427 is offline
A bad bearing shouldn't cause a wobble but a bent axle will ruin a bearing and seal.
-John
Old 03-27-2010, 11:17 PM
wdfp's Avatar
wdfp
wdfp is offline
When you have the axle out changing the bearings and seal, have a local with a lathe chuck it up and spin it to see if its straight. Unless you see an obvious problem. More than once I have seen bearings run so long after they should have been changed that they wore a groove into the axle itself, some even lost their wheel from it..
Old 03-27-2010, 11:36 PM
gus11208's Avatar
gus11208
gus11208 is offline
it kinda sounds like your axle shaft might be bent
Old 03-27-2010, 11:45 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
It's more likely the flange is bent rather than the shaft.
Josh
Old 04-24-2012, 04:04 AM
jlacek's Avatar
jlacek
jlacek is offline
Rear wobble
hi, new to this site, hope I am posting correctly. I bought an 86 ford F250 6.9 2wd last June. It has a slide in camper on it. I got a flat tire with the camper on it. The tires were bought in 05 and had only 5000 miles on it. the tire separated around the edges. Jacked up the camper, changed the tire and had no issue until I picked it up from the ford dealer after having the ignition cylinder replaced. I noticed right away that there was a wobble driving off the lot. Drove to a tire place and had two new rear tires installed. The wobble is now worse. Took truck back, they re-balanced and re-installed new tires. Wobble seems worse. Any ideas? Jennie
Matt Endres
08-04-2017 07:42 PM
995.4SD
1999 to 2016 Super Duty
17
08-12-2016 12:38 PM
PinkyRingz
6.4L Power Stroke Diesel
10-17-2015 01:27 PM
Kdr358
13
03-17-2012 09:10 AM
memphis
06-06-2003 12:17 AM
Quick Reply: Rear Wheel Wobbling
