Summit 750cfm carb??? Any good??
Summits are good but I'd get a 600 or smaller. For the 460 also. Those truck engines would almost never benefit from anything bigger. I had a 750 holly on my wifes buick 455 but it was a factory high compression 93 octane minimum engine. Big difference from a truck engine.
For pulling power and low end torque go smaller. Not bigger. It will just waste gas.
The best one I ever had on my boss 302 was a 600 cfm spreadbore holly. Not sure if you can even get those anymore. I had webers, edelbrocks, carters, even one of those predator pieces of junk on it. The SB holly was the winner. That car would tear the tires off like nobodies business when I switched to it.
The 390 f350 I had was a 600 holly and while it would do some amazing wheelstands while pulling stumps out, it was really wasting fuel. The other poster was serious about it running gas out the tail pipe. Mine did quite literally. I couldn't find a 4 barrel any smaller though and I hate motorcraft carbs.
Wow. I'm saprized how small a cfm these motors run on considering how bad the mpg is. I'm planning a total performance build when I drop in a 460. 400hp is where I want to be, I did some reasearch and can upgrade a holley 600 easy enough. And it should make more power than a 750 anyway. Can you jet a carb so it doesn't waist as much fuel???
RSpaeth
01-20-2016 10:12 AM
nitemandick
19
04-07-2003 11:38 PM
