Maual primer on fuel pump?
#33
These pumps only draw 3-4 amps. The electronics energizes a coil that pulls the plunge against a spring allowing fuel to flow through the hollow plunger. the valve in the end of the plunger then closes sand the spring pushes the fuel out of the pump. If they are deadheaded, the plunger will try to cycle but it can't move leaving the electronics uneffected. Running them dry could damage them since the plunger will cycle without lubrication or cooling.
The switch from Summit is a 3 prong, 3-5 psi switch. It has a common and anormally open and a normally closed contact. GM uses them on their EFI engines for the idiot light and fuel, pump control. A junkyard item if you're short on cash.
If you are concerned about saving power by removing the MFP, it only uses about 0.0004 HP to pump 0.1GPM at 7 PSI. The electric will take about 0.06 HP to do the same job. Just a thought!
As I've said before, you don't have to eliminate the MFP. If you mount the EP between the MFP and the EP you will not push fuel into the crankcase.
#36
#37
Back from the dead
I am looking to complete a setup similar to that in post #8 on my e350 with a 7.3 idi that has had air intrusion issues since I purchased it.
I will be the first to admit that I don't know the 1st thing about working on a diesel motor...with that ignorance, I am trying to get some input on what the line which is now connected to the auxiliary pump in post 8 was originally leading to. Any help is much appreciated.
#39
Can you give us a picture of where you put yours. I bought a primer bulb but I'm unsure where to put it.
#40
The rubber hose comes from the mechanical fuel pump, through that squeeze-bulb, and then into the intake of the separator.
#42
Either that, or just whack it down near the pump and use that end as a fitting -- slip it into hose.
I'm actually not sure on this rig; it was already converted to rubber hose by the PO; I just added the squeeze-bulb.
I've replaced the other side with rubber as well, actually(filter to IP), but that's very recently.
#43
#44
Received 3,108 Likes
on
#45
My 87 f350 has a hand primer pump on drivers side firewall.
So, I'm grinding my 94 IDI turbo this morning and she won't start. (Has been running fine) After a while my neighbor came down and said sounds like you lost your prime - where's the manual primer on your fuel pump. Understand - I just got this truck and I'm new to Fords, and I had been asking myself the same thing, having had a Toyota diesel in the past with such a thing. Neither he nor I nor my manuals nor my searching on FTE has revealed that my rig has a manual primer - sure can't see one, if it there!
So, tell me, am I blind, or what? And, if there isn't one, then what do you do? I finally took the filter off (was going to change it anyway), changed it and filled it with some Diesel Kleen and now I'm waiting for my batteries to charge up again (yup, I ran them down pretty low). Can you folks confirm or not re: manual primer on the fuel pump?
Thanks, in advance, for the great help. I love this site!
EMD_DRIVER
09-14-2008 04:53 PM
