1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Exhaust manifold problems
Old 03-18-2010, 07:47 PM
gmetime24's Avatar
gmetime24
gmetime24 is offline
I have a super duty 99 ford F250 V10 and have bolts on both sides that are broken off. They rusted out and fell off and some point and I would not be surprised if others fell off when they are replaced. I went to a local muffler man to have the muffler replaced and they are the ones who brought it to my attention. Muffler man told me they could fix both sides for around $800.00. I went to another mechanic to see what other estimates I could get and they told me they would have to lift my engine out of the car to get at the bolts and gave me and estimate around $2500.00!!! Does that seem right or do they not want to do the work?? Can this be done with the engine still in place?? Any advice would be great. Thanks
Old 03-18-2010, 08:16 PM
maddogken's Avatar
maddogken
maddogken is offline
i got a guy to do one side for $80.00
Old 03-18-2010, 08:23 PM
02mudbug's Avatar
02mudbug
02mudbug is offline
it can absolutely be done with the engine in the truck. is seems that 600 to 800 bucks is what most people get quoted to fix this at private shops. If you pull the inner fender liner and the shock tower you have full access to all 20 studs. I am waiting for a weekend that the weather cooperates that im not obligated to help someone with something to install the ebay headers and remaining 16 studs and nuts on mine, I've already done the 4 that were broken off. Plan on having more of them break off, the key is several days of hitting them with penetrating oil before you try to get them out.
Old 03-19-2010, 11:32 AM
Ricohman's Avatar
Ricohman
Ricohman is offline
Can be done on your driveway with hand tools.
Took me a couple of days after work.
Old 03-19-2010, 12:30 PM
twall_SD250's Avatar
twall_SD250
twall_SD250 is offline
it defiantly can be done by anyone. i done mine yesterday in 1 1/2 days. i had 2 broken stunds and a crack exhaust manifold. all my bolts were rusted and corroded but i got lucky and not one broke off when i took it apart. like i said i did the whole job in a day and a half, just make sure befor you start spray the heck out of all the old bolts with BP Blaster and let it sit for a few hours if not overnight
Old 10-02-2010, 06:53 PM
F-7's Avatar
F-7
F-7 is offline
Can someone tell me the best replacement studs for this problem. I am doing it next weekend and don't want to replace them and have to do it again! What size are they? Thanks in advance
Old 10-02-2010, 07:01 PM
brownie83's Avatar
brownie83
brownie83 is offline
when i did it on my 03 v10 i used flange bolts. i forget the actual size. if you search in the v10 forum, there should be a good thread about the size and how to do it. i used about 4 LEFT hand drill bits and flange bolts. cost me about 35 bucks and a weekend of work. good luck
Old 10-02-2010, 07:15 PM
F-7's Avatar
F-7
F-7 is offline
Thanks Brownie
Old 10-02-2010, 10:45 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
I used the stock studs from ford which now are stainless steel...IMO I would use them as well as the stock nuts which are a mix of metals. I had to weld nuts on the broken studs to get them out with a mig welder...not fun but I got it done..NPI.
Dick
Old 10-03-2010, 08:19 AM
Boris2000's Avatar
Boris2000
Boris2000 is offline
Talking
Dick
What Dick said! I had like 8 broken studs. Got them all out in less than 4hrs. Heat from the welder helps loosen the broken studs.
Old 10-03-2010, 02:47 PM
ak-angler's Avatar
ak-angler
ak-angler is offline
I believe the originals were SS, too. The new ones are just a different grade.
Old 10-03-2010, 03:15 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
In 2003 they came out with the SS units before that they were steel..
Dick
Old 10-03-2010, 04:48 PM
ak-angler's Avatar
ak-angler
My '03 has at least seven broken studs right now. So... are you saying that these are the new, improved "stainless" studs?
I stand by my earlier statement. All of them are stainless, just different grades. But, in either case, it's irrelevant. Ford did change the studs at some point. The problem is that they're only marginally better than the originals. And, there's still plenty of reports of failures using the new ones.
kramerpage
2004 - 2008 F150
23
02-12-2015 11:11 PM
the_justin
03-20-2013 07:36 PM
Fish_Scientist
04-15-2012 05:55 PM
zhilton
01-01-2012 09:00 PM
rob_engineer
07-18-2011 07:29 PM
Quick Reply: Exhaust manifold problems
