85% ethanol in the tank
i stopped at a gas station to fill diesel fuel for my truck, just right at the yellow handle pummp ( standard color for diesel fuel) and pump about two gallons,then realized what!!!!!!!!!!!! so started reading the tag " for 85 % ethanol only" ...
what should i do?? drain the tank?? please help....
thanks you
thanks you
Did you run it on that tank? was the tank empty? If it were my truck I would fill the other tank up full and run on that. then siphon as much as possible outa the ethanol tank then fill that one up full with diesel to dilute it and put a little lubricity in it like 2 stroke oil bioD or what you usually use. then sneak into it with your dash switch. you should be ok keep it real full for a while
dont run on that. drain the tank. if you already ran a little on it, empty the fuel bowl also and drain the fuel rails in the heads. Close the fuel rails, fill the fuel bowl with fresh diesel and get it running.
I may even try do empty the fuel lines. But it may be ok just doing the above.
Gas and alcohol even more so, is very dry, burns hotter and ignites earlier (lower flash point)...very bad for your diesel. We trashed and engine in a farm tractor once because the fuel we had delivered had gas in it...not 85% by any means, but a few tanks ruined the motor.
Even reading the pump is no guarantee. A couple years ago in Albuquerque a fuel depot that fills the tank trucks that deliver to gas stations screwed up bigtime. They contaminated gasoline with diesel fuel and delivered it to about a hundred stations. Cars were breaking down everywhere. Repairs ran between $500 and $1000 for each car, which was paid for by the fuel company - by raising prices of course!!
I agree with farm69 about the regular thing. Not sure about ethanol. Our trucks can be run on up to 30% gas as recommended for extremely cold climates. I really don't see why ethanol would be that much different. It actaully has less energy per gallon than petroleum. Do what you figure is best for you. I'd just fill the rest of the tank up with diesel and run it. I've blended many times in my PSD and tractor for the winter. Running on straight or really high concentration gas is very bad, however 2 gallons on a tank of 15 gallons is still only 13% gas.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
thank you all,
right after finding out that i pumped wrong fuel, i switched to rear tank and run on that. The front tank has about 5 gallons of diesel left when i pumped 2 gallons of 85% ethanol fuel.
just for caution, i think i gonna drain the tank and fill it up with diesel when the weather here in Niagara Falls NY get warmmer.
I really appreciated all.
thank you all,
87-XL-Squared
29
03-07-2015 12:23 PM
LARIAT 85
35
03-12-2011 09:09 PM
