Should be a 239 flathead V8. If I remember correctly, 8BA heads were cars and small trucks, 8RT heads were for larger trucks and EAB heads just had larger compression. I believe that the EAB heads are the best of all three.
If I'm wrong, then someone will be along shortly to correct me.
I had thought (and this is fairly loose in the knowledge department)...but, I had thought that the 8BA heads were used on the 239s up to 1951, the 8RTs were from the 239s 1952and up. The EAB engine wasthe 239 used in the cars in 1952 and although it had the same bore and stroke as the other engines developed 110 (as opposed to 100) gross horsepower.
This is from looking at the shop manuals from the 49-51 (non supplimented) Truck Shop Manual, and the 1952 Ford Car Shop Manual. There is no mention of EAB heads in the 48-52 Ford Truck Chassis Parts Manual.
8ba-8ab-eab-8rt the most common heads you will see. i believe 8rt started in 49. you're engine seems to be a 239-100 hp "flattie". pumping out a whopping, (if you're lucky), 90 hp to the back wheels.
