Engine Type
Old Mar 10, 2010 | 12:04 PM
lbrauer's Avatar
lbrauer
Engine Type
What size engine is this the number off the head is EAB 6050D 4OU. I think it is a flathead 239 but am not sure.
Old Mar 10, 2010 | 01:20 PM
51PanelMan's Avatar
51PanelMan
Should be a 239 flathead V8. If I remember correctly, 8BA heads were cars and small trucks, 8RT heads were for larger trucks and EAB heads just had larger compression. I believe that the EAB heads are the best of all three.
If I'm wrong, then someone will be along shortly to correct me.
Old Mar 10, 2010 | 08:20 PM
lbrauer's Avatar
lbrauer
Thanks
Thanks for the information Panelman that is what I thought it was too but wasn't for sure.
Old Mar 11, 2010 | 01:15 AM
Julies Cool F1's Avatar
Julies Cool F1
I had thought (and this is fairly loose in the knowledge department)...but, I had thought that the 8BA heads were used on the 239s up to 1951, the 8RTs were from the 239s 1952and up. The EAB engine wasthe 239 used in the cars in 1952 and although it had the same bore and stroke as the other engines developed 110 (as opposed to 100) gross horsepower.
This is from looking at the shop manuals from the 49-51 (non supplimented) Truck Shop Manual, and the 1952 Ford Car Shop Manual. There is no mention of EAB heads in the 48-52 Ford Truck Chassis Parts Manual.
Just FYI, the 337s were listed as 8EQs
Old Mar 11, 2010 | 09:55 AM
petey shoes's Avatar
petey shoes
8ba-8ab-eab-8rt the most common heads you will see. i believe 8rt started in 49. you're engine seems to be a 239-100 hp "flattie". pumping out a whopping, (if you're lucky), 90 hp to the back wheels.
Old Mar 11, 2010 | 04:49 PM
lbrauer's Avatar
lbrauer
Thanks for the information people. Ya'll are the best.
Old Mar 11, 2010 | 04:52 PM
lbrauer's Avatar
lbrauer
Ya'll are the best
Thanks for the information on the truck engine size and the horse power on it.
Old Mar 12, 2010 | 09:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
EAB6050D .. Left Hand Cylinder Head-Cast Iron / ID marking EAB-6050-D cast on top side of head.
Original application: 1953 Ford Passenger Car 239.
1952 239 Passenger Car L/H cylinder head: EAB6050C / Marked EAB-6050-C.
jowilker
Nov 10, 2012 10:43 AM
bigfordman70
Jun 10, 2012 07:55 PM
Pastmaster
13
Jun 24, 2011 09:20 AM
Syzle
Apr 16, 2002 07:55 PM
truckfarmer
Nov 27, 2001 05:24 PM
