I smell GAS!!!
I smell GAS!!!
Need some advice please......
I own a 90 Bronco, 351efi. All I can smell is gas from the exhaust pipe. Not so much unburned gas, but the smell of burned gas. I put in new plugs, wires, rotor, distributor cap, various injector cleaners and octane boosts into the tank, and have the same result......the smell of gas. As a matter of fact, it seems the timing is out some, and no matter the adjustment I make, I cant seem to get the timing perfect.
Any suggestions or answers are surely appreciated!!
........Scott
........Scott
if you smell fuel that isnt good. pull the oil dipstick and smell the oil. if it smells like fuel you need to stop driving your rig.
check the fuel pressure at the rail with a gauge. also pull the vacum line off the fuel pressure regulator and if gas comes out that part needs replaced.
also when you set the timing you need to pull the spout connector.
Ford Fuel Injection for pulling codes, setting the timing properly etc..
Thanks for the advice ya'll,
I will have the codes run on it.
Gas cap tight.
Question about the rail pressure.....How many pounds am I looking for, and it something I can use a tire guage on? and also, where is the fuel regulator located?....Oh, there isnt any smell of fuel in my oil, thank goodness!
.......Scott
Gas cap tight.
.......Scott
Hankster1958
12-08-2016 08:01 AM
ford4fun1947
09-12-2016 06:19 PM
