6.2L V8 Discuss the 6.2L V8
Replacing connectors on COP (broke the red tabs)
Old 06-12-2018, 07:16 PM
memilanuk's Avatar
memilanuk
memilanuk is offline
Started in on replacing the plugs, wires and boots today. Been a *looooong* time since I did a plug job on a truck; probably last one was my '86 F150 with the 300 ci straight 6. Man things have changed!
So... I'd read that the little red tab on the connector from the wiring harness to the coil-on-plug units needed to be pulled back... check. Did that. Unfortunately, I hadn't read this thread, so I just thought those connectors were still really stuck on there. One came off willingly; a couple... did not. Looks like I busted the locking tabs inside the connector
Now I know better... hopefully the other 12 will go a little easier
How much of a PITA is it to replace those connectors? Is it the same process as shown in this video (https://youtu.be/wMgKZ-AQwhM)? Are they parts the local Ford store is going to have in stock (in the video the connectors look slightly different from what I have, and he's using parts cut off another vehicle at the wrecking yard)? Or are they going to try to sell me a whole new wiring harness?
Old 06-13-2018, 06:39 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
why replace them...
the red is the second lock... not the only lock.
YES, they are easy to break.
Old 06-13-2018, 08:57 AM
memilanuk's Avatar
memilanuk
Originally Posted by Chuck's First Ford
why replace them...
I didn't just break the red tab... I broke the main one as well. The whole connector just slides off/on now - no latch at all.
Old 06-13-2018, 05:29 PM
Chuck's First Ford
can you install a ty-rap.... to hold it..
them connectors are hard to get.. so I understand.
Old 06-14-2018, 03:00 PM
memilanuk's Avatar
memilanuk
I don't know about 'hard to get'... but they are pretty proud of the little buggers
$20-$25 *each* for a connector plus pigtail @ Rock Auto, plus expedited shipping to get it here Monday at the earliest... or $42 each from the Ford dealer, and it should be here tomorrow.
Ouch.
That was an expensive lesson.... but still cheaper (by half) even with the 'extra' parts than paying the dealership to change the plugs.
Old 06-18-2018, 03:05 PM
Towinrig's Avatar
Towinrig
Towinrig is offline
Jason Wetmore
08-21-2015 06:30 AM
bigcountry1009
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-10-2015 01:06 PM
shabby14
05-04-2013 04:34 AM
cps
02-11-2012 09:39 AM
BobbyB
09-29-2011 05:59 PM
Quick Reply: Replacing connectors on COP (broke the red tabs)
