Bang noise when tightening a bolt
I was tightening a bolt a few weeks ago to see if it would stop a leak and it made a loud pop and moved 1/4 a turn. Bolts still tight, bolts not stripped I didn’t try tightening it anymore after that. It was on the T-stat housing, I didn’t take it off and still haven’t. I’m taking it apart tomorrow.
The following users liked this post:
Received 3,108 Likes
on
Something happened when the bolt made the noise. You are lucky the bolt didn't break off in the intake manifold. I suspect the threads in the hole may be stripped and you should check that by re threading the bolt (not to tight) now and make sure it has not stripped or is loose in the hole. You can visually check the bolt threads before you do that. If they are messed up replace that bolt. Final torque on the bolts for the housing are ONLY 12-18 ft lbs. That isn't much and is easier to achieve with an inch torque wrench. If you do it by hand just snug them to firm and if it leaks you can always go a little more. You don't want to break the bolt in there, ask me how I know.
The following 2 users liked this post by Anonymous12:
HKusp
19
06-19-2010 04:56 PM
gator1gear
12-23-2009 05:08 PM
Raised with Ford
04-14-2005 06:50 PM
