Misfire HELPPPPPPPPPPP!
Which Coil is and plug is misfiring? 2000 ex, 6.8 v-10. Started her up this morning to go to work and it was skipping from the get go. Ran great last night. Who would have thought it would just....eh crap out? But anyway can anyone tell me how I can figure out how to find out what coil is bad without it tossing a check engine light? I would have thought it would have thrown a check engine light? Pulling each coil and installing a good one, taking it for a ride and repeating untill it doesnt skip anymore seems a bit redic... Any help would be appreciated. I also have the new snap on scan tool at my disposal but its brand new and my bud is not sure if it will show him what cyl is mis-firing unless theres a code
anyone have any ideas other then running it hard to try and get it to set a light? What about taking the temp with a laser temp sensor at ever exhaust port? would this work? In my theory, I am thinking that all the header pipes on the exhaust ports would be running in close proximity of temp and the one thats not firing would be significantly cooler..???? I have gibson headers not the stupid exhaust manifolds....
on
Man, talk about ansy. The rest of the world on the left coast is still working while yer having fun. JUST kidding.
I have talked to a ford techy about v-10's and using water to wash motors, and the infamous damage with water in there.
His response was not to worry, and infact when they need to diagnose a misfire that is not running a code yet they use a water\vinegar mix and spray around each boot\plug area while running which usually trips a code. What they have found when looking at this they found the boots usually malfunction and then the cop goes out.
You may also want to replace all the boots with new and use dielectic grease around the seat and the contacts to the plug when installing new. Don't forget to first blow out any debri\water first from that area before the new boots.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
FTE Ken
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
01-30-2008 12:29 PM
mitchymitch
1997 - 2003 F150
29
03-11-2004 07:15 PM
