M50D Top Cover
my bad LOL it is the one farthest from the engine...but im pretty sure there are plugs at both ends
Had this happen to my truck somtime last summer, but i got the parts from ford. I was lucky and broke the 1/2 fork in nuetral, so i had to start at stop signs in 3rd. Good old 300 did though.
Id be scared that when it happened it was in gear, then putting it in another using a different fork. POP, bad things would happen.
Glad you got it fixed.
You fixed it a lot faster than I fixed mine.
And to fordman 1090 mine broke while in second if i let the clutch out i could feel the transmission twisting the whole truck, certainly a bad thing. After a long time of fiddling it went into neutral then it was 3 hard 3rd gear starts to get home. Clutch didn't like it. Did I mention I actually drove 5miles towards my house stuck in second before i managed to get it into 3rd?
Yep, I did that too. I believe it's held captive inside the rod - there's a spring in there too IIRC. It wasn't too bad to re-load - just hold it in place as you tap the end of the rod in.
That's just from memory though combined with what I think would make sense. I recall I was only "pretty sure" I was putting it back correctly as I too wasn't paying attention very close when I pulled it apart. I guess I got it right - it's been fine.
nepsis
12-04-2009 03:40 AM
