2008 SD keyless entry code, RAP, computer module
VictoryRider9,
Welcome to FTE .
Glad you found an answer to the problem.
You will find a lot of very good and useful things
here and if you look under the engine type for you
truck at the top of that forum page you will see a Tech Folder
In there you will find even more goodies to help keep
things going smooth and if you ever a problem lots of help things.
Also in this section there is a "New Member" Thread where you can introduce your self.
You can use this link or get there from the main page of this part of FTE.
https://www.ford-trucks.com/forums/7...questions.html
Sean
Welcome to FTE .
Sean
Hey there, new to the group.. I've had my truck since Sep of 13, had 136k miles when i bought it..
Vehicle: 2006 Ford F-350 Super Duty
Category: Not Selected
Sub-Category: Not Selected
Drive Type: RWD
Transmission Type: Transmission 5-Automatic(5R110W)
Engine Base: 6.0L - 8Cyl
Sub Model: Lariat
My truck was broken into and my radio was ripped out.. I have the dash apart now installing a new radio.. I'm also looking for the elusive code on the RAP module for the door locks. I'm pretty sure it just aint there..
I'm assuming i have to get robbed by the dealer now to pull it..
Drive Type: RWD
Sub Model: Lariat
Looks like I may be the welcome wagon.
Welcome to FTE Kevgrn114
Come on over to 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You can find more about the 6.0 there and other things
Did you find the VSM? That sticker was removed around
the 2007 year I think. But you need to look on both sides
of the module.
If you know someone that has one of the better scan tools
they might be able to read the code. Also if you know someone
that has access to a Ford VCM with IDS software they can read it.
I got lucky with mine and the card was still in the owners manual
that luckily was still in the truck after 145K miles.
Sean
of the module.
Sean
HEY I FOUND IT!!!!!!
It is WAY back in there.. and the decal is facing up. The radio is already out and the dash is off. I had to remove another black box that sits behind the radio, the the VCM was behind that.. I had to reach up through the storage bin to push up on the white insulation and a conduit hose, then with the other hand stick my iPhone up in there and start taking a bunch of pics until i captured the far back corner of the decal and could just make out the numbers! :-) man what an ordeal.. If I didn't already have the dash ripped apart it would have been horrific! :-) I can now push buttons to open the door.. Hmm, sounds mundane when I put it that way..:-)
#30
thank you guys estan said it was behind the passenger side kick panel and fuse bow and sure as **** there it was plain as day.also genegladden thank you also it was right where you guys said it would be .feels good to save 100 dollors,aslo for future inquires i have a 2009 F250 super duty crew cab.5.4L
plj6656
1997-2006 Expedition & Navigator
02-24-2007 07:10 AM
vadphoenix
2004 - 2008 F150
05-04-2006 10:31 AM
