Condensation in valve covers.
Aside from a leaking head gasket or some other "mechanical" malady the first thing I'd check is your PCV system. If your PCV system isn't working properly it will allow condensation to build up. If you're not allowing your engine to warm up completely ie short trips down to the corner store etc. that will also cause condensation. Frequent oil changes will remedy that. Other than that, I can't think of anything else off the top of my head.
i used to live up there for 5 years and i dont miss it one bit the way it mists and drizzles outside. it used to happen to my truck once in awhile too. mostly the breather cap is what would have coffee-ish residue on it. compression and leakage tests passed, plus antifreeze was always bright green, so i think it just happens sometimes from the moisture. but it hasnt happened since i lived up there. a certain amount of moisture builds up in the crankcase of any vehicle no matter the age, make, or model of it. and there are probably 5 different websites i have read and can point out that explain this is why if a vehicle is in storage, running it for 10 minutes once a month and then putting it away again is not beneficial and can actually increase condensation. i used to change my oil every thousand miles up there and people thought i was nuts.
Vortilon's suggestion is right on. My truck has a 195 degree thermostat and performs great even in the Georgia summertime.
condensation
I did a oil change today, fe352 block, since this is a fairly new buy for me I am checking things out and found it had a broken valve cover bolt, leaking oil everywhere and they tried to silicon the bolt hole.
I tapped the bolt and straightened out the edlebrock VC's and used rubber gasket. I noticed condensation too. I thought about it and feel that the PVC was never hooked up to the air cleaner and a high moisture situation developed because of poor cuirculation. I live in dry bone california...
I have a edelbrock air cleaner now with a port to pull air from one Valve cover, the other one is vented. I will let you know if this will fix it and what I find at the next oil change.
lbj
03-24-2017 08:41 PM
