Engine can be turned backwards but only forward to the same spot
Started new thread, trying to bring a 2001 250 back to life for a friend. Could put squirt of gas in throttle body and it would start. Put a fuel pump in and cranked it and got a backfire. Seemed locked up next key turn. Took plugs out took belt off. Could not turn engine over forward. Took starter out put screwdriver and moved engine backward. Went to a ratchet on crank. I can turn it over multiple times backward. Forward it comes around to the same spot and stops??
kevinarnold021692
08-26-2010 09:13 PM
