camshaft for the IDI: "The torque cam" Typ4
Old 02-04-2011, 10:15 PM
BIG BAD BENTON's Avatar
BIG BAD BENTON
BIG BAD BENTON is offline
how do you get one of these cams? i want one
  #62
Old 02-04-2011, 10:25 PM
Jayme Duty's Avatar
Jayme Duty
Jayme Duty is offline
Just my opinon, These motors do very well stock and the amount of power you can increase per dollar is not worth it.. There are simple modes that are great like the soup bowl and welding in a $10 piece of tube in place of the muffler for a straight pipe. I do love all the threads with all the custom intakes the members have created but once again just my opinon, the spending 100's of dollars for a couple hp not for me.
  #63
Old 02-05-2011, 11:42 AM
wreckinball's Avatar
wreckinball
wreckinball is offline
that it is bro, that it is! lol. But i can tell you, its more than a couple HP with my exhaust and intake i modified. i hear what you are saying but if no one ever changes anything, no advancements can be made.
  #64
Old 02-05-2011, 11:54 AM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
you also have to look at the long term gains as well. It brings your pak hp and torque down a fe hundred rpm's. Saves fuel and wear on the enginee. Sounds like a good option to me bud
  #65
Old 04-16-2011, 01:54 PM
Royson12's Avatar
Royson12
Royson12 is offline
I am assuming a cam out of a 7.3 will work for the regrind? It would get installed in my 6.9 with new rollers, rebuilding the motor right now anyway. Gonna have a banks sidewinder waste gated on it. How do i get it done?
  #66
Old 04-16-2011, 02:06 PM
fordhorse's Avatar
fordhorse
fordhorse is offline
talk to russ on oil burners
Oilburners.net
  #67
Old 04-16-2011, 02:08 PM
oreocreaming
type4 is his name here and there, spelled different in obe of tem but basically te same
  #68
Old 04-17-2011, 05:41 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Im curious about taller ratio rockers as well, and idea that had occured to me a lil while back. Anyone know off the top of thier heads what ratio ours are? Little head machining and i think we could put about any rocker on there.
Next, does anyone know how good our valve springs are to X rpms? Is there a stiffer spring alternative?
  #69
Old 04-17-2011, 06:11 PM
rhkcommander959's Avatar
rhkcommander959
rhkcommander959 is offline
Depending on their shape, stock are good up to 4k MAYBE. I've heard of others using stiffer springs but IDK where I read it, I'll go diggin
  #70
Old 04-17-2011, 06:21 PM
hairyboxnoogle
Hey man ya sure dont have to but thanks if ya do. Plannin the 4k governor for my 6.9.
  #71
Old 06-09-2011, 12:16 AM
Marianna2003's Avatar
Marianna2003
Marianna2003 is offline
It sure would be sweet if an existing rocker setup could be used in the IDI. Has anyone looked into this?
  #72
Old 07-24-2011, 02:07 PM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
I hear the 7.3L rocker swap onto a 6.9L, but whats the real difference?
  #73
Old 07-24-2011, 02:30 PM
rhkcommander959
they are stronger or more reliable... I cant remember 100%
I have been reading from a couple guys that PSD springs should fit without modification/machine work.
  #74
Old 07-24-2011, 03:52 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
just send a pm to Russ.
the guy who replied to this thread in post #2:
https://www.ford-trucks.com/forums/9...ml#post8513377
  #75
Old 09-12-2011, 12:44 PM
sak778's Avatar
sak778
sak778 is offline
dyno?
So has this cam been dyno'd before and after yet?
oreocreaming? Have you done this yet?
Anybody???
Updates?
YMMV
Quick Reply: camshaft for the IDI: "The torque cam" Typ4
