camshaft for the IDI: "The torque cam" Typ4
iv been curious if there was ever an aftermarket cam for the IDI engine since i bought it.
here's some info iv gathered from oilburners for others. sounds pretty decent guys.have a look.
Originally Posted by typ4
(Post 375729)
The torque cam was designed by the cam grinder I use, for the loggers when these trucks came out. They designed it for na and I used it in my turbo engine and it pulls , hard.
I sell them as they are a wholesale shop. these two quotes go together:
Originally Posted by dyoung14
(Post 411126)
could you give me more info on that cam you got? i might be interested in one:sly
(Post 411130)
No because they wont give me more info, they developed it for the loggers in the late 80's
189 exchange plus shipping I do know that.
(Post 375824)
The cam is 189.00 exchange plus shipping, So shipping both ways, to return the core is about 45 I would guess.
Originally Posted by ameristar1
(Post 376124)
We are all trying to crack the code on this engine, because most of the time you either say, "ok, I can live with the low power" or "that's it, I'm going to put another engine in this thing ( and it's usually a Cummins )." To the loyalist of IH, it's blasphemy, but at the same time there hasn't been a serious street combo that has held together and delivered the goods. And yes, it gets very expensive after a while. That's why we are looking for the cork in the bottle, and consensus is saying the cam. Russ' cam is the beginning, I am looking into more radical stuff, and that will depend on where pistons and valves meet. It's going to take a little time, but hopefully something will get made that will allow the engine to do 300hp without excessive amounts of boost.
Bigger pumps, injectors, turbos, ported heads, etc. can't do what they are meant to do when the cam timing won't allow it.
(Post 373992)
The cam timing holds this engine back. The general consensus with most people that have commented so far about the 6.9/7.3 is that the heads can flow the air, the intake certainly has the volume, and it has the size. The injection pump can produce the fuel volume stock, and the injectors can be made to flow. But in the end, especially based on the numbers seen on the chassis dyno, there is a serious mismatch somewhere. And, like one poster said on another thread, most folks don't want to push these engines.
Even though more boost would be desireable, because of the cam timing the engine has a hard time processing it all. It's like the engine, as configured with the stock cam timing, is fighting itself, and the added boost makes a bad situation worse. So goodbye weakest link in the cylinder. Freight Train asked me if I would sell a cam that would work with the stock bottom end, and I turned him on to Jones Cam Designs (704-489-2449) so he and anyone else who wanted something special can get it made. I talked to Mike yesterday and he can get a lot done with the stock cam core, as a regrind. Russ (typ4) has a torque grind that works really well. the person who sells these cams for ours IDI's is: typ4 @ oilburners.net typefour @ this website (FTE) this guy describes the cams job well.so i'l post it for others here to:
Originally Posted by spencergt66
(Post 374029)
Well you just asked a whole mouth full. The camshaft is one of the most important parts of the engine it will make the engine make power in higher rpms or lower rpms depending on how its configured. On a conventional engine N/A usually the more lift and duration you have the better the engine preforms @ higher rpm but with a diesel engine, turbo charged that is, Usually the rpms are lower and the torque is made lower there for the time that the valves are held open during operation or travel of the piston is less cause the engine is being force fed air,turbo charging, instead of relying on vacuum.
Now this is where you need to pay attention to where your valves open and close. On a turbo charged engine before the end of the exhaust stroke both the intake and the exhaust valves should be open for a given amount of time, valve over lap, creating what they refer to as scavenging. This is when the charge air from the turbo is pushing out any remaining exhaust gases before starting the intake stroke usualy the intake valve stays open more than the entire downward travel of the piston (180 degrees of crank shaft rotation) say the intake opens @ 10 degrees BTDC exhaust stroke and stays open until 35 degrees after BDC intake stroke or 35 degrees into the compression stroke. Right here is where what engine types differ. Most conventional engines are still letting charge air into the cylinder during the upward stroke or compression stroke, like our engines IDI's, this cause more heat and cylinder pressure at TDCC Where as other engine types close the inlet valve before the intake stroke has ended thus letting the charge air expand in the cylinder. And when a volume of air that is already compressed, from the turbo, and is let re-expand quickly during the downward piston travel it becomes cooler decreasing the amount of cylinder pressure and heat in the combustion chamber. When this system is used it is necessary to have a larger quantity of charge air to make up for the air expansion in the cylinder Therein lies the problem and possibly some solution to the IH IDI turbo engines. Because the 7.3 IDI inlet valve closes @ 42.8 degrees ABDC , from what i was told, the inlet air is crammed in there to the point where its probably being pushed back out of the cylinder due to the length of upward piston travel. More then likely if the inlet valve was closed before the bottom of the intake stroke then you could have more charge air less emissions and a better balanced engine;Sweet Hope that helps
(Post 374048)
My cam grinder split patterns the cam and increases the intake lift to 261 lobe lift/392 valve
exhaust remains stock with 253 lobe 380 valve. rocker ratio is 1.5 they calc it at .050 tappet lift. the intake centerline is opened up to fill the cylinder longer.
(Post 374058)
They developed it in the na days for the loggers, those trucks sold by the thousands in OR and WA. It really works good in my engine with the turbo. I can outpull my buddy and I have 355 gears and haul about 13k with the camper on and the buggy trailer.
Originally Posted by david85
(Post 374085)
Well crap! maybe a custom cam is in the works for me after all, Russ. Didn't realise the stock cam was a smogger retard like the ford big blocks.:mad: And here I was thinking these engines were untouched by emission devices. Turns out the enemy was from within all along.
Had no idea that the scavenging effect often described in the detroit 2 strokes borrows over to these 4 stroke engines. Great breakdown of the theory there, spencer!!!!
(Post 374317)
The things needed to design a cam properly for a 4 stroke engine are the same regardless of fuel type and injection system type. The OEMs do spend a lot of time doing what they do, but most of the time it still is a compromise, and lets be real; the people who count the money don't want the motor running too good. I've seen this happen over and over. The engineers come up with an excellent design, but can't get it produced. So instead, they are told to only go so far and not any further. When it comes to truck engines like the 6.9/7.3, they just put enough cam in there to make it run and not break.
With almost 30 years of advancements since this engine was produced, we can now have cam profiles that can wake these older engines up and make them live up to their potential. I would like to see an IDI hit 200-250hp before a turbo gets brought into the picture. I believe the heads, compression and fuel are already there to do that, but the cam has not been up to snuff, not by a long shot.
(Post 374640)
According to Russ, the rocker ratio is 1.5 to 1, Gary gives the lobe lift at .253, so total lift at the valve is .380". I got a chance to see the ports on the heads, and like one other poster said, they are huge. This cam doesn't tap the full potential of airflow available with the stock heads and induction system.
This could be a sticky for this info, over on OB also.
Thanks for digging it all up. |
i think that price is very fair typefour and more people should know you offer one.
i see people asking all the time how to add power to their IDI.a cam swap is a pretty easy engine mod.so i figured id post all the key points since i was searching anyway. looks great! she's on my "mods list" :-X22 |
I totally agree the cam should be addressed and it's great knowing it was. With that said does Type IV have any before/aft dyno #'s. Let's face it, proof sells, not just that seat of the pants feel. We need someone to supply before/aft data of the same engine with a stocker and a costum grind cam.
Type 4 have you any info as to what rpm it changes the peak torque to, If it lowers it a couple of hundred rpm's it would be great. Hmm I happen to have an extra cam too.
I guess the upside to the whole mess is it will bring what russ and mel actually offer out of the woodwork...God knows neither of them have an ego, advertise or shove things down your throat....i would love to know more details on the cam, and what kind of performance improvement can be seen both n/a and forced induction
I have wondered about different cams for these engines. I just figured that like every thing else they got over looked. It seems that I was wrong about that. Now if I can convince the boss to let me spend even more on this monster I will have one.
You guys do realize that in 83 when ford introduced all they had to do was best the 6.2 chebby. They could have done that with a diesel sticker on the fender.
It was not in Fords or Internationals best interest to make them too good, as if no upgrades ever came out your customer base will be happy with the one they already own. |
So do you think they changed the cam over the years? Would the 86 engine I am running be any different from the origanal 83 engines?
I don't think the cam was changed but the compression was.
Ya that part I was aware of. I have thought about cams for these engines ever since I swapped mine in. I just figured we were over looked by the rest of the world as is usually the case lol.
I will see if the grinder knows anyone who has dynoed the cam before and after. I have not. I will have raw numbers of my truck this spring and I will list all mods also.
This cam has a little more intake lift and the lobe sep is changed a little. Oh and thanks for the kind words. |
russ...in all of the above quotes it sounds like the original design was for NA, but you installed it on a turbo with no ill effect...is this correct?
the other question is how noticable of a change was it? (obviously thats subjective, but seing as I am looking at tearing down the motor and freshening it up before I boost it, $200 seems like a reasonable amount if the butt-dyno is happy while waiting to get boosted) |
Wow, I would love to have one of these things. If I can see some nice dyno numbers or some really good before and after reviews I will gladly buy one.
I was tempted to swap the cam at the same time as when I put the moose pump in. I regret not installing new lifters at the time of my engine rebuild so those could have been swapped out at the same time but it was not to be this time around.
Maybe next year or something. Discussions here and on OBN have lead me to the conclusion that the camshaft is a bottle neck in these engines. I heard that Russ was going to put his truck on a dyno eventually so that could be something else to look forward to. |
