2001 f250 7.3 Diesel running good, quit firing on some of the cyclinders, lost power
Old 04-23-2011, 08:35 PM
jchjhh's Avatar
jchjhh
jchjhh is offline
Drove home. Started up the next day, drove good plenty of power and then after driving about 1/8 mile, lost power again. Any suggestions on the problem and what I should check for.
Old 04-23-2011, 08:57 PM
fuelman's Avatar
fuelman
fuelman is offline
Do you have a scanner or something to do a buz test? Possible IDM heating or solenoids getting heat saturation. Also IPR orings could be leaking after warm up lowering oil pressure to injectors. Any codes?
Old 04-27-2011, 09:56 AM
jchjhh's Avatar
jchjhh
jchjhh is offline
I do not have a scanner. Been told it is probably the wiring harness or computer. Anyone had these problem
Old 04-27-2011, 02:58 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 04-27-2011, 03:14 PM
Deluxe06's Avatar
Deluxe06
Deluxe06 is offline
4000 rounds a min
Sounds like the classic UVCH syndrome. One of your Under valve Cover Harness may be coming unplugged.
Here's a thread for you to read; https://www.ford-trucks.com/forums/8...ck-shakes.html
Old 04-27-2011, 09:29 PM
Newfiestang50's Avatar
Newfiestang50
Newfiestang50 is offline
Yep, sounds like my issue exactly which turned out to be my drivers side UVCH.
My post is here if interested.
https://www.ford-trucks.com/forums/1...arm-fixed.html
Papas66
16
04-23-2014 10:57 AM
fordpride
Escape & Escape Hybrid
10-21-2012 07:45 AM
mnmwhit
12-05-2010 11:14 AM
Diesel_Dirk
31
03-09-2009 01:01 PM
cdunn
1983 - 2012 Ranger & B-Series
11-22-2004 07:43 PM
Quick Reply: 2001 f250 7.3 Diesel running good, quit firing on some of the cyclinders, lost power
