Backflush Oil Cooler
Old 02-03-2010, 07:14 PM
jagski2's Avatar
jagski2
jagski2 is offline
I just finished changing my oil cooler and doing an EGR block off. This is just a thought that I have. Remove the CAC on the pass side, remove the egr flow cover on the oil cooler. You would need to get or make a nipple to fit into the coolant outlet on the oil cooler, remove the lower rad hose at the radiator. You would want to have a high volume-low pressure water source (water pressure regulator on a garden hose). Since you would be doing a full flush, it could be repeated a couple times. Most of the junk would flow through the water pump and out the lower hose.
I took my old cooler, flushed it with a hose and had a full water flow after. If I had to replace my oil cooler again, I would try it. Any thoughts would be appreciated. Thanks Jim
Old 02-03-2010, 07:36 PM
RescueF250's Avatar
RescueF250
RescueF250 is offline
Id just replace the cooler itself.
Old 02-03-2010, 08:03 PM
jagski2's Avatar
jagski2
jagski2 is offline
I did insall a cooler kit, but when I took it apart, I saw that the cap on the oil cooler for the egr coolant source would be very easy to get to for a back flush. Beats $245 for a cooler kit, $50 in misc junk and 10 hours of work.
Old 02-03-2010, 08:06 PM
cheezit's Avatar
cheezit
cheezit is offline
If your luck that may clear up a blockage on the coolant side. you need to think about this though... its a liquid to liquid cooler. that means you need to back flush the oil side aswell so its no really possible to do that.
Old 02-03-2010, 09:01 PM
jagski2's Avatar
jagski2
jagski2 is offline
I did not think that the oil side was any part of the problem, being that the oil is filtered. Unless the 6.0 owners have digital oil and water temp gauges or the new flash, they would never know about a plugged cooler until it was to late. After seeing the water flow direction and that the egr cap on the oil cooler is easy to get to, at least the junk could be loosened up, flushed out and the rest cleaned out with a coolant filter. Since I have a new oil cooler, I won't need to do this, but I may with the next flush. It's a shame that when we bought these trucks 7 years ago, a coolant filter would have saved us alot of money. Well, thats why I LOVE this site.
Old 02-03-2010, 09:22 PM
cheezit's Avatar
cheezit
cheezit is offline
not gonna fight on this. but the oil side of the filters have been knowen to plug aswell. Remember even the best of filters is only 98% effective. that means that 2% gets by. also keep in mind that is spec for a new good filter. as time goes by the 98% can drop. this is also spec on the ford filter. there are others that are not 98%.
Old 02-03-2010, 09:34 PM
jagski2's Avatar
jagski2
jagski2 is offline
No fight from me. I was hoping to hear your input. Thanks Jim
Old 02-03-2010, 09:57 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
So if the oil cooler is prone to clogging not only on the coolant side but on the oil side as well, in your estimation, what would be the percentage of failed coolers due to oil plugging?
Old 02-03-2010, 09:59 PM
cheezit's Avatar
cheezit
cheezit is offline
its not high and not common but happens. I deal with many worst case trucks in a fleet heavy shop
Old 02-04-2010, 12:05 AM
RescueF250's Avatar
RescueF250
He's right they do clogged over time. Good example mine I have the original one in mine dated back to 2003. When I tore it apart there was some good restriction in it. These trucks are picky do it cheap and your gonna ask for problems later.
deputydog03
1999 to 2016 Super Duty
09-28-2016 01:36 PM
BryanStein
09-23-2015 10:54 PM
Pierdobek
11-30-2014 11:27 PM
ve7kilohertz
07-14-2012 03:39 PM
SHOOTER22250
05-22-2012 11:24 PM
Quick Reply: Backflush Oil Cooler
