Rear axle swap?
Old 01-26-2010, 04:06 PM
dougbrown's Avatar
dougbrown
dougbrown is offline
Rear axle swap?
Could I take a rear axle on a new 99-02 F250 and swap it to my 96 F250? I want disk breaks all the way around for better stoping power. Could it be done if I found one with the same gear ratio?
Old 01-26-2010, 04:20 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
I think you can doug, but let someone else who knows better tell you. I do believe they sell kits to convert drums to discs so you won't have to swap the whole thing.
OT, I think it would be cool to put in a split rear w/5 speed manual! I wonder if that has been done yet?
Old 01-26-2010, 04:36 PM
chicagodragon's Avatar
chicagodragon
chicagodragon is offline
the lug pattern is different
Old 01-26-2010, 06:46 PM
dougbrown's Avatar
dougbrown
Ok so i run new 250 rear rims. But it is possible.
Old 01-26-2010, 07:00 PM
wmiller's Avatar
wmiller
wmiller is offline
the super duty has metric hubs OBS has standard. I think it can be done but takes some modifying to get the park brake to work and would have to change the poportioning valve. Don't quote me to this there may be more to it
Old 01-26-2010, 07:53 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
i had measured them at one point. the springs were centered the same, so in theory it would "bolt in" but you would have the wheel differences and teh driveshaft mount is different, plus you still have to modify the park brake cables. in my opinion its cheaper to either build a disc kit (about 300 in parts) or buy the disc conversion
Old 01-26-2010, 08:39 PM
fuelman's Avatar
fuelman
fuelman is offline
Search Tjbeggs He did a post about 2yrs ago on how he made his. Had parts required n everything.
Old 01-26-2010, 08:45 PM
c00nhunterjoe
https://www.ford-trucks.com/forums/8...-brakes-6.html
to make it easier-
Wearever rotors---------YH145251 - $57.99 each
wearever silver pads- --- NAD-52 -- $14.99
Cardone calipers rt side-- 184124---- $17.99+$15.00 core
cardone calipers Lt side-- 184125----$17.99+$15.00 core
True torq ft hoses ------- H98925---$32.99 each
Caliper hose bolt(help isle) 13940----$4.28 each
the rotors are 2 yr warrenty
calipers are lifetime warrenty
pads are lieftime warrenty
hoses are 1 yr replacement
Old 01-26-2010, 08:52 PM
fuelman's Avatar
fuelman
fuelman is offline
With that list what do you use for the mounting hardware for the calipers.I thought TJ used Chevy van or something.
Old 01-26-2010, 08:54 PM
c00nhunterjoe
the calipers come with the bolts. the calipers, lines and pads are from an 80's chevy pickup front end and the rotors are off a 96-97 ford 350 van rear.
Old 01-26-2010, 09:02 PM
dougbrown's Avatar
dougbrown
thanks guys!
Old 01-26-2010, 09:08 PM
dougbrown's Avatar
dougbrown
Joe what did u make the breaket that the caliber mounts to or where did u get it?
Old 01-26-2010, 09:25 PM
c00nhunterjoe
tj emailed them to me, you can get them from "bronco graveyard.com" i printed them out and used a plasma cutter to cut the brackets out of 1/2 inch plate. its a one peice mount plate.
Old 01-26-2010, 09:31 PM
dougbrown's Avatar
dougbrown
You would happen to still have the email would you? If not I'll pm Tj. I have a cutting torch so that will do.
Old 01-26-2010, 10:56 PM
joe_13894's Avatar
joe_13894
joe_13894 is offline
FYI, someone is making late 70's / early 80's Cadillac Eldarado calipers again. The Cadillac Eldarado had rear disk brakes with a mechanical parking brake. People started using them for every vehicle imaginable to convert the rears over to disk, and they quickly became hard to get. Now they are available again in the ~$80 range.
Quick Reply: Rear axle swap?
