2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
07 Expedition Tune up Cost
Old 01-26-2010, 08:49 AM
mylo's Avatar
mylo
mylo is offline
I want to ask for your advise. I am at 88,000 miles and am getting ready to have the plugs changed on my 07 expedition. I am aware of the plug issues so I will have a dealer perform my tune up. The vehicle has a ford certified used warentee untill 100,000 miles so I fugured that I would have a dealer do the work. I have called around to try to get a understanding of how much they charge for the standard tune up and how much if a plug breaks. Here is what I have found:
Ford dealer A near my work. They charge 199.00 for the tune up and 99.00 per broken plug. They said they can have it done in a day regardless of how many break. They said even though the new vehicles get a revised plug mine still gets the old designed plug.
Ford Dealer B by home. They charge 549.00 to remove/replace the plugs, plus time and materials. They said it can take up to 3 days to remove the plugs, and that typical cost is 800.00 to 1,300.00 per tune up. They said that there is a redesigned plug that is one piece, so this won't happen again.
Ford Dealer C 30 minutes from home. They charge 324.00 to remove the plugs plus one hour per plug that breaks. They did not mention a redesigned plug at all, but they did not know how Dealer A could offer a tune up for that cheap, since the plugs are 18.00 each.
Independant non ford garage. I called a local garage that some some neighbors have had good luck with. They charge 324.00 for the tune up which will cover one broken plug. After that it is time and materials.
All of the places I called said that they have not had to do a head job to remove a broken plug. My questions are why is there such a difference in price from all of the ford dealers? How can Ford Dealer A charge 199.00, that seems really cheap (I have called them back three different times to make sure the price they gave me is correct). Is there a redesigned motorcraft plug? I asked one dealer if I brought in the champion plugs if they would install it. They said they would but there would be no warrente. And lastly what would you do? Thanks for your help. Kevin
Old 01-26-2010, 09:27 AM
bearfoot_25's Avatar
bearfoot_25
bearfoot_25 is offline
I would not run a champion spark plug in my lawn Mower!!!! I would not run anything but Motorcraft and Autolite in your Expedition.
This problem with the plugs you are talking about. My 2002 Expedition uses the same spark plugs as your 2007, and i have never seen nor heard of a 2 piece spark plug could you elaborate a bit on that?
Old 01-26-2010, 09:33 AM
fordtech08's Avatar
fordtech08
fordtech08 is offline
stay away from B that price looks way to much I was thinking the price should be about 300-400, stick with the ford plug. also ask the dealers what the hourly rate is my guess is that B has a varible hourly rate. if I were you I'd go to C
Old 01-26-2010, 09:34 AM
fordtech08's Avatar
fordtech08
they don't have the same plug nor engine 3v vs 2v
Old 01-26-2010, 09:57 AM
mylo's Avatar
mylo
mylo is offline
I was thinking about using C.... the only problem is I need to check to see if they have a loaner car, where as if I use dealer A they could drop me off at work. I'm just wondering if dealer A is using high school kids and they are being supervise by a certified technician.
From what I know the two piece plugs are pressed together with the ceramic and electrode as one part and the threads and nut as the second part. Somebody chime in if I have this wrong. What is happening is that carbon is building up on the elctrode of these super long plugs and basically when you unscrew them the center portion remains in the head while the threads and nut come out. Again I could be wrong on the exact details of this but it is something close to this.
Old 01-26-2010, 11:04 AM
bearfoot_25
Hmm learn something new everyday!!! I used to be a technician at a dealership and i had never heard about this issue before but i just realized yours is an 07, and i havent worked at a dealership since 04.
Old 01-26-2010, 12:40 PM
fordtech08's Avatar
fordtech08
yeah that is about right on the plugs, as far as updated plugs ford has changed the design for 08 and up to where the whole thing has threads, but it has updated heads also
Old 01-27-2010, 12:29 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
this is the place I would go
I typically see $250-300 for the work...so $200 is a great price IMO
If you use them, get that pricing in writing. Especially the $99 per plug part. It sounds like they are very well versed in the 04+ 5.4 3v motor.
On the other hand, that $200 might be because they just do the plug change and don't follow the TSB...then rely on the Lisle Extractor to remove all of the broken plugs...which is probably all 8
are the on drugs?
the plugs PZT-2F are only $7-10 each. maybe they are $18 per plug at a rip-off dealership
regarding the plugs...the new plug is only for 2008+ 5.4 3v motors. There is a company CHAMPION who makes a 1 piece plug...but some people have had issues.
see bold
the price difference is all about the bottom line...and how much business they recieve.
I'm betting the Dealership with the best price gets a ton of business. They have enough volume to lower their prices and still do decently.
Old 01-27-2010, 07:50 AM
mylo's Avatar
mylo
mylo is offline
I really am hoping that the 199.00 price is because of volume and not because they don't follow the tsb and just breakoff the plugs. We will see. I am going to have the tune up done on Thursday. I am crossing my fingers.
Old 02-01-2010, 01:06 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Ley us know how your tune up comes out.
Old 02-14-2010, 02:19 PM
JerrySC's Avatar
JerrySC
JerrySC is offline
Not To Get Off Subject But..
You are having a vehicle serviced at a FORD dealer. They are performing routine maintenance (plug change). Because of a FORD design flaw, the dealer is passing on additional labor costs to you, the customer. Can anyone spell class action law suit?
Old 02-14-2010, 05:24 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
That idea was tossed around on the Mark VIII boards for years and never got anywhere. The standard headlights on all the '93 through '96 would dim to the point of being totally ineffective at night and even worse in a heavy rain. The '96 Mark VIII with the LSC package came with HIDs and they are much better and I upgraded my lights when a pair became available for $500. The dealers last price that I have heard of is around $1000 each! All that ever happened with the head light issue was everyone waited for the NTHSB to force Ford to retro fit all early Marks with the HIDs. Needless to say we are still waiting. When I decide to give up my mark I'll probably part it out as just the head lights are worth almost as much as the car.
Old 02-15-2010, 12:27 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
Unfortunately, Ford is not standing behind the design flaw. they have updated the heads, provided a TSB to improve the procedure and the lisle tool is also available to extract broken plugs.
It's my understanding that Ford has changed the plug design to be a one piece plug for all affected engines.
Tim
Old 02-16-2010, 05:38 PM
benshere's Avatar
benshere
benshere is offline
I know this plug issue has been beat to death (deservedly so), but since it is once again on top, I have a question that probably has been asked elsewhere------if you dont mind !
Can any of these thread sealants be used around the "nose" of the plug-----with care not to get any on the tips. I am thinking of the aluminum "slop in a can" that I use all the time for small engines, and large, with aluminum heads or on bolts that tend to clog up with rust etc. There is also a "copper" based sealant in a can, applied with a brush.
GABAR
2015 - 2020 F150
16
06-07-2017 11:36 AM
thousand_mile_stare
2004 - 2008 F150
21
11-13-2015 12:43 AM
026TB4U
1997-2006 Expedition & Navigator
11-23-2013 09:22 PM
Texas Chain Ring
22
10-04-2012 07:57 AM
GIO23
11-04-2009 09:06 PM
Quick Reply: 07 Expedition Tune up Cost
