Snow buckets
Old 01-25-2010, 08:08 PM
nymo's Avatar
nymo
nymo is offline
Snow buckets
Anyone got any good tips for getting all the snow out of the bucket when you tip it. After awhile it seems like only about half the snow will dump and the bucket stays half full no matter how much I abuse the hydraulics.
Old 01-25-2010, 08:37 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
I assume we're talking about a skidsteer/loader/tractor bucket here so I'm gonna say try coating the bucket in Fluid Film before you start. Shaking is the only other way I know of getting it out.
Old 01-25-2010, 08:53 PM
nymo's Avatar
nymo
nymo is offline
You're right; it's a skidsteer.
Old 01-25-2010, 09:01 PM
7.3 Rocket's Avatar
7.3 Rocket
You can always try tapping the bucket on the ground a bit. Note: I mean tapping not smashing.
Old 01-25-2010, 11:07 PM
fellro86's Avatar
fellro86
fellro86 is offline
Slick paint like what is used on grain wagons, otherwise, not a lot can be done if it is a sticky snow.
Old 01-26-2010, 12:32 AM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
Old 01-26-2010, 07:56 AM
websthes's Avatar
websthes
websthes is offline
You can pick up some stuff at Canadian Tire will keep snow from sticking to your equipment. Forget what it's called but it's a clear fluid in a squeeze/spray bottle. I used it on my snowblower all around the chute and the auger and it does a good job keeping the slush from sticking to there.
Old 01-26-2010, 01:20 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
The fluid film stuff does work if your paint is good, but if you have a rusty bucket it'll still stick, but at least it'll stop rusting.
The best thing would be to steam clean it, keep it warm and put on two coats of self-etch primer and then at least three coats of Rustoleum, then the fluid film. Do this every year before the snow season and you'll be set.
Old 01-26-2010, 06:09 PM
Buck 1's Avatar
Buck 1
Buck 1 is offline
Believe it or not: Use a can a Pam, the spray that your wife uses to coat the inside of the frying pan. Works like a charm!
Old 01-26-2010, 07:40 PM
websthes's Avatar
websthes
websthes is offline
I was thinking diesel fuel. When I worked on the paving crew we used to coat everything with diesel to keep the asphalt from sticking.
Old 01-26-2010, 10:00 PM
nymo's Avatar
nymo
nymo is offline
Thanks for the suggestions
Old 01-27-2010, 10:57 AM
websthes's Avatar
websthes
websthes is offline
Around here we get a lot of snow. So in winter, construction shuts down, and the companies fit up their front end loaders and trucks for snow removal. And what they do is put really big buckets on their front end loaders.
A bucket of snow is lighter than a bucket of gravel. If this is a regular thing you might want to look into getting a bigger bucket.
Old 01-28-2010, 04:58 PM
wizzard351's Avatar
wizzard351
wizzard351 is offline
we use backhoes at work to push/lift snow and when theyre left outside the buckets stay extra cold and the snow dont melt to it and stick neer as bad. when the boss put them inside over nite the snow sticks realy bad
Old 01-29-2010, 01:52 PM
DanoFF50's Avatar
DanoFF50
DanoFF50 is offline
Former Vendor
Fluid Film will work for that application. In fact, if anyone on here hasn't tried it and lives in the U.S., just shoot me a PM with your contact info and I'll get a sample can out for free.
We've got a Canadian distributor who might supply samples for Canadian members. Just PM me for his info.
jimandmandy
22
03-30-2009 05:37 PM
fireball 440
94
12-25-2008 11:55 PM
Snowbunny
26
12-03-2007 01:00 AM
rellik74
18
01-05-2007 04:57 PM
christop43
17
03-20-2002 07:35 PM
Quick Reply: Snow buckets
