A Heli-Coil Question
My '88 has a problem holding it's water.
The problem is that one of the two bottom bolts that hold the water pump on has stripped threads in the weld nut on the inside of the front plate of the engine.
I can pull the front of the motor apart and put a new front cover on, but what a PITA.
I can drill and put a Heli-Coil in it, change the oil and put the bolt back in the bottom of the water pump but I thought that I would ask here first if anybody has done this fix before and what the results were?
Thanks in advance.
Ron
Almost forgot, GO COLTS!!!!!!
Thanks in advance.
Ron
Smellii
11-27-2012 01:21 PM
Samsonitesamsonite
12-05-2010 09:19 PM
