Weird noise question!
Old 01-23-2010, 05:38 PM
catan70's Avatar
catan70
catan70 is offline
2002 f150 4x4, just started last night all of the sudden. Its a weird noise coming from it sounds like my rear passenger tire. When im under 10 mph it sounds like everytime my tire spins around it makes a clunking noise. I cant figure it out. I have got under it a few times already thinking maybe a rock or something like that is somewhere but i saw nothing. Its a really loud noise. Anyone have any ideas. thanks i appreciate it.
Old 01-23-2010, 05:52 PM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,210 Likes on 1,701 Posts
jack it up off the ground ,put it on axle stands & try it in drive really slow & listen.Don't forget to block the front wheels,Gigger
Old 01-23-2010, 06:02 PM
edford1's Avatar
edford1
edford1 is offline
weird noise
My friend has a 2000 F150 that had a noise in the same area. We pulled the wheel and found that the E brake assembly had come apart inside the rotor. Check it out !
edford1
Ron W.'s Avatar
Ron W.
Ron W. is offline
If you're moving that slowly have somebody walk along to confirm it's coming from the brake area, if so take it apart. I'm thinking you truck has rear discs, if so the friction material on the park brake shoe may have let loose.
But step one would be to confirm the source ...
Old 01-23-2010, 07:21 PM
eallanboggs's Avatar
eallanboggs
eallanboggs is offline
Where is air inlet for PCV system on 5.4 3 valve V8?
started new thread
Old 01-23-2010, 09:35 PM
catan70's Avatar
catan70
catan70 is offline
thanks guys ill those are some good ideas. The prob is im traveling right now so i will have to take in to somewhere. Should i take it into some place like discount tire and have them take a gander at it?
BigNick98
15
02-04-2014 11:17 AM
STILLEN/EXEPIDITION
1997-2006 Expedition & Navigator
09-08-2008 10:23 PM
ilranger
1983 - 2012 Ranger & B-Series
04-17-2005 06:57 PM
lawless
02-05-2003 06:52 PM
Quick Reply: Weird noise question!
