engine size after boring
If it's the new displacement you seek I calculate out 395.35, but then again a 390 really calculates out to be 389.56; I'm just curious why you care? For all practical purposes you still have a 390. It's kinda esoteric otherwise.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Stock Man
The older engines which pertain to this list have a cubic inch displacement which can be calculated by figuring the volume of all of its cylinders in cubic inches. The formula is:
pi(3.1415927) * (bore/2)squared * stroke
Sorry for the mess: standard 390 bore is 4.05" and stroke is 3.78" ; Use the formula to calculate a standard 390 and you should get 3.89.56; I hope this helps.
Stock Man
Stock Man
so what's the formula for converting cubic inchs to metric? I have tried to extrapilate ratios based on things like 302=5.0L but chevy says 5.0L=305. 80ci Indian is 1500cc, 74ci Harley 1200cc. When I have tried to do the math I think I have been dogged by close enough and rounded off numbers. I have a 305 Camaro and was surprised how different the bore and stroke are to a 302. The 305 shares the same crank with the 350 but has a much smaller bore than the 302. I'm also intrigued by the new triton v10. I think it's 6.8L isn't that a little bigger than my 390? (actually my 390 is .030 over as well).
It appears that Ford is a little bit guiltier of fudging the numbers. It looks like the 300 & the 302 are 4.9L. A 350 is a 5.7L a 351 is not quite 5.8L. I am curious about the new triton family. according to my calculations a 5.4L is 330(almost). I wonder if the same bore and stroke combination was used as the FT 330? Anybody know where to find info about the triton family?
ALL AMERICAN BOY
04-24-2017 08:16 PM
ManfredVonRichtofen
04-20-2017 08:32 PM
Santiagoeford
07-24-2015 08:19 PM
Rmc292
09-11-2013 08:37 PM
F-250 restorer
01-23-2010 05:19 PM
