Opti-Lube XPD
I've been using it for over two years. I buy 3 gallons at a time to get free shipping. The only place I know to get it is directly through the Opti-Lube web site. In over two years of use, I haven't had any issues. Prior to the Opti-Lube, I was using Power Service Diesel Kleen. I switched to Opti-Lube after seeing the lubricity test results that showed Opti-Lube was the second best lubricity improver behind Bio-Diesel and well ahead any of the other products tested. That convinced me to switch. If Bio-Diesel was available in my area, I'd go that route and use Diesel Kleen for the cetane boost.
lubricity, stablity and cetane
<TABLE border=1 borderColor=#000080 cellPadding=3 width="100%" height=794><TBODY><TR><TD bgColor=#ffffd2 height=606 vAlign=top borderColor=#000080 width="50%">BENEFITS INCLUDE:
Minimum Treatment Rate: 1 to 512 minimum (.25oz per gallon of fuel)
Recommended Rate: 1 to 256 (.5oz per gallon of fuel)
Read Our Diesel Fuel Improver FAQ
MSDS Available HERE
Available by the Quart, Gallon,
5-Gallon Pail and 55 Gallon Drum
</TD><TD bgColor=#ffffd2 height=606 vAlign=top width="50%">Opti-Lube XPD is the ultimate in performance fuel additives.
Improving Lubricity is just the beginning, this product also improves efficiency and cleans injectors. Cetane in improved by at least 3 points, fuel will flow down to -20' F
Opti-Lube products protect your equipment by providing exceptional lubrication in the fuel system (recently ranked in the top four products in an independent study, view it here).
Test Results:
Cummins L10 Injector Cleanliness Test:
All our diesel fuel on the mid-atlantic seaboard comes from the same pipeline at Cetane-40. What the distibutors and retailers add to it is anyone's guess. And i imagine they don't really care how long your engine will last. IMO lower milage engines will benefit greatly with this additive, from fuel pump to cylinder wall. High milage engines, maybe not so much.
I have a low milage 7.3 PSD. It is my 4th diesel truck. I use it.
</CENTER></TD></TR></TBODY></TABLE>
- Enhanced Lubricity for
Reduced Fuel System Wear - Improved Fuel Economy
- Increased Power
- Reduced Deposits
- Reduced Emissions
- Less Rust & Corrosion
- Injectors are Cleaned
- Improved Storage Stability
- Improved Water Separation
- Improved Cold Weather Performance
MSDS Available HERE
>20% Average reduction of Injector deposits
ASTM D- 5001 Wear Test:>35% Wear Reduction
ASTM D- 2274 Stability Test:>75% Improvement
Fuel Economy Test:>5% Improvement
<CENTER>Made in USAAll our diesel fuel on the mid-atlantic seaboard comes from the same pipeline at Cetane-40. What the distibutors and retailers add to it is anyone's guess. And i imagine they don't really care how long your engine will last. IMO lower milage engines will benefit greatly with this additive, from fuel pump to cylinder wall. High milage engines, maybe not so much.
I've been using it for about two years as well and also purchased 3 gallons to get free shipping. Previously was using Diesel Kleen. I really didn't notice any improvement in sound or mileage over the Diesel Kleen. Since the DK is cheaper and more available, I'll be switching back when my current stock is used up.
Power Service's distribution network is second to none. You can buy it practically ANYWHERE.
(When you burn as much as 600 gallons of diesel a WEEK, like I do, this makes a BIG difference.)
-blaine
Its now pretty easy to get it and get it delivered right to your door. The TDI club has a group buy on Gallons for 4.75 shipping per order and free shipping on 5 gallon pails.
TDI Club link
Opti-Lube Group Buy - Free shipping on gallons - TDIClub Forums
Direct to order site
Diesel Fuel Lube ? Save Money on Your Opti-lube Order
TDI Club link
squaredancer
30
03-04-2013 09:29 AM
brkncly
6.4L Power Stroke Diesel
10-09-2012 11:33 AM
