F350 Transmission interchange???
The 351 and 300-six share the same bell housing bolt pattern and thus use the same model ZF. You can find one in two-wheel-drive over 8500 GVWR F250 or F350 with a 300 six or 351 from 88-91. The same transmission was used up until 95, but I'm not sure if the 92-up versions have a provision for mechanical speedometer drive. Here is an application chart that may help: http://www.zf.com/na/content/media/i...ion_Charts.pdf
HotRod 66 F100
13
08-28-2014 09:27 AM
militaryvet1428
06-23-2014 10:40 AM
Daleksandrovich
04-09-2014 02:17 PM
terrylamar
01-31-2010 05:40 PM
