HELP!!!!!! transmission.....
Old Jun 23, 2014 | 01:11 AM
militaryvet1428's Avatar
militaryvet1428
I have a 1989 F-150 with a problem. The only numbers i can find on the side of the transmission are E9TA-AA. The auto parts store told me that no such transmission exists. I need to find a replacement transmission to fit my truck. It has a 5.0 V8 engine and the transmission needs to be a 5 speed manual overdrive. Has this transmission been discontinued or can I get a replacement? Please any help would be appreciated.
Old Jun 23, 2014 | 06:03 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Does it have square or diamond reinforcing ribs on the outside of the case?
Square = Mazda
Diamond = ZF
Old Jun 23, 2014 | 08:08 AM
militaryvet1428
They are square.
Old Jun 23, 2014 | 08:09 AM
militaryvet1428
I called the Ford Motor Company and they couldn't tell me anything eather.
Old Jun 23, 2014 | 08:49 AM
F150xlt's Avatar
F150xlt
If you have a 4wd you can use any Mazda M5r2 also called the MO5r2
used on F150's and full size Bronco's from 88-96.
If you have a 2wd you need a M5r2 from a F150 or full size Bronco from 88-91. 92-96 had no provisions for a speedometer gear.
There was a version of the 2wd M5r2 used in the Tbirds and I believe Cougars.
This version won't work with your F150.
The M5r1 is the weaker version of the M5r2 and was used in Rangers, Bronco II's and Explorers. This will not fit your F150.
Old Jun 23, 2014 | 09:01 AM
militaryvet1428
Thanks @ F150XLT!! I was almost getting to the point of chasing down someone driveing the same truck as mine and asking them! Lol. This info is extremely helpful.
Old Jun 23, 2014 | 10:05 AM
F150xlt's Avatar
F150xlt
What is the problem with your trans.?
The most common failure are the 3 rubber plugs in the back edge of the shifter cover shrink and let fluid out of the trans. This causes the bearings to fail.
Another failure is the plastic pivot ball the shifter rides in cracks which causes sloppy shifting and causes the two shifter pivot pins to wear.
You should have no problem purchasing parts for this transmission. Search for M5r2.
There are parts and complete transmissions on E-bay and Craigslist. Your local junkyard should have complete units.
Old Jun 23, 2014 | 10:20 AM
militaryvet1428
I think the whole damned thing whent out. I was going 65 down the freeway and all of a sudden I heard a loud thump and my rpm's redlined. I got it over to the side of the road, put in first, let the clutch out and I started rolling backwards. I went through all the gears, same thing. Exept 4th. I still had 4th. Lol
Old Jun 23, 2014 | 10:37 AM
F150xlt's Avatar
F150xlt
Sounds like a major failure.
If you do purchase a used one remove the drain plug and verify it has Automatic Transmission fluid in it (Red color). I purchased a used one and found the prior owner filled it with 90w gear lube to quiet down the noisy bearings.
You should be able to find a used one in good shape locally for $150-$250
Old Jun 23, 2014 | 10:40 AM
militaryvet1428
That doesn't sound good...
Bigal700
17
Apr 13, 2014 10:27 AM
2speed
Aug 11, 2010 03:15 PM
Loganwildman
Aug 15, 2007 04:30 PM
buick64
Missouri Chapter
Aug 6, 2007 11:23 AM
Dungeon_Master
Jan 30, 2005 07:58 PM
