1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Worn Leather Steering Wheel Cover ...
Old 01-06-2010, 07:55 PM
98SurplusExpy's Avatar
98SurplusExpy
98SurplusExpy is offline
The "black color" on the leather steering wheel has worn away on my 2006 Lariat; the leather is still smooth on most of the worn spots and only "rough" at the most heavily worn spot at the 12 o'clock position. The truck spent the majority of it's life in the Texas sun .. you can see the damage in this picture:
A new steering wheel (P/N 5C7Z-3600-CBA) runs $336.45 form the best online Ford Parts Dealer that I can find.
I did find a place in Dallas, TX that does an exceptional job at recovering steering wheels ... "Dallas Custom Steering Wheel" ... but these guys want $250 +shipping to do the job.
So I think I'm gonna try to re-dye it myself. I've located two vendors with "kits":
Leather Magic; Leather Recoloring Kit ... $49.95
Leatherique; Steering Wheel Kit ... $25.00
Has anyone tried this or have a familiarity with these brands?
Old 01-06-2010, 08:51 PM
F350-6's Avatar
F350-6
F350-6 is offline
That's another reason I've always avoided the Lariat. I don't like leather seats or steering wheels.
I don't know how long the dye would last. Another option, especially with your dash, would be to upgrade the wheel. Here's a link to what my wife did to her truck. https://www.ford-trucks.com/forums/7...ml#post6855987
Old 01-06-2010, 09:25 PM
2002 F350V10's Avatar
2002 F350V10
2002 F350V10 is offline
Here is a better solution. Hands down the best replacement is the combo wood and leather wheels sold on ebay where they redo an oem wheel. You send yours back after the swap. My 02 F350 had a cheapo wheel with a small diameter and a cheapo feel. I bit the bullet and swapped it for what I described. Huge difference. Then I did the same swap on a work 99 ex. fantastic. Then I was at the pick a part yard and got a leather wheel for an 01 F250. The worst feeling and looking wheel was that one. Going to swap it again for what I described. Easy swap accomplished in 1/2 hour or so.
Old 01-06-2010, 10:35 PM
msalyer's Avatar
msalyer
msalyer is offline
Black liquid shoe polish works wonders. I bought an old Corvette once that the wheel looked WAY worse than yours. I figured I had nothing to loose so I used sandpaper on the real rough spots (gently) and a couple coats of the polish. Turned out quite good. It faded a bit in a year or so and another coat fixed it up again. saved a lot of $$$$$.
Old 02-04-2010, 11:14 PM
98SurplusExpy
As a follow-up ... I ended up sending the wheel to get recovered.
The leather pro's I contacted said the cover was too far gone to re-dye ... mostly 'cause it was worn to the point that it was "suede" in places.
Don Le @ Dallas Custom Steering Wheel did the recovering .. it was pricey, but I can say that it looks equal to, if not better, than factory. The shop has my recommendation
Old 02-05-2010, 01:25 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Looks real good. How long did they have your steering wheel?
Old 02-05-2010, 10:29 AM
98SurplusExpy
Two days to do the work ... the rest was shipping time (NC / TX). I sent it out on 1/25 and got it back on 2/4.
Old 02-05-2010, 11:17 AM
labrown's Avatar
labrown
labrown is offline
How is the steering wheel removed? How is the Horn/Airbag removed? I am having a problem with my horn. It goes off on it's own. Had to pull the fuse on the side of the road last month. I'd like to look at it but don't know how it is removed.
Thanks in advance.....
Old 02-06-2010, 12:14 PM
98SurplusExpy
To remove the Airbag ...
- Disconnect battery (both batteries if Diesel).
- Turn on Light Switch for about a minute or so; also press brake pedal. This will purge any remaining energy in the system.
- Pry off the two little covers on the back side of the steering wheel.
- Using a 8mm socket (1/4" Drive) w/ 4" extension, remove the two bolts that were behind the covers (will have to look in the holes to see bolts).
- Carefully pull Airbag away from wheel & disconnect the two electrical connectors
- Hope that the Airbag does not blow in your face
- To install, reverse procedure ... tighten bolts to 9 lb-ft or 108 in-lb
To remove Steering Wheel ...
- Use a T-50 Star socket and remove the center bolt holding the steering wheel to the column. Workshop manual instucts to discard the bolt & replace with new.
- Use a gear puller (do not bang with hammer) to remove the steerig wheel from the column stem.
- Disconnect one electical connector & remove wheel
- To install, reverse procedure using new bolt. Tighten to 28 lb-ft. (note ... column stem splines will only allow steering wheel to go on one way.)
Old 02-06-2010, 12:22 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
wouldnt removing the power from the system, make it so the airbag has no way to trigger ??
i'm thinking of having my wheel swapped out at some point, cuz my wheel is very much like your original, but i wanna hold out for one of those Ebay wheels, with the sectional carbon weave treatments.
since my interior has the factory carbon look inserts having the wheel to match would be a nice upgrade, and i like the look to boot.
Old 02-06-2010, 12:29 PM
FX4 5.4's Avatar
FX4 5.4
FX4 5.4 is offline
by any chance do you wash your hands with gojo or fast orange? these types of products eat away at a leather steering wheel. My dad is a mechanic and washes his hands frequently with gojo and ruined the leather steering wheel in his dodge in about 2 years
Old 02-06-2010, 12:45 PM
98SurplusExpy
Nah ... the wheel on my truck got a taste of the Texas / Mexico sun.
Old 02-06-2010, 02:51 PM
Fordfanatic4life
mine was worn when i bought the truck, but it must have seen alot of hiway miles in a row, cuz it has alot of mile for a newer truck.
200K miles in 5 years, when i got it. seems like it must have been used as a RV hauler alot. esp given the fact it had a 5th wheel/trailer combo together when purchased from teh owner. i didnt buy the 5th wheel thou.
Old 02-06-2010, 08:59 PM
98SurplusExpy
That's for the "how to remove the airbag" description ... you'll wanna depower the Airbag before removing. Of course, it should be reconnected once reassembled to the wheel and before the batteries are reconnected.
Old 02-07-2010, 05:34 AM
Nice Work Truck's Avatar
Nice Work Truck
Nice Work Truck is offline
Do you have a link for the site?
Quick Reply: Worn Leather Steering Wheel Cover ...
