1997 F350 crew 4x4, 7.3 turbo fuel system
looking for help with 1997 7.3 fuel system, after parking the truck at night the diesel fuel will transfer from rear tank to front tank! changed the FPR with a new one, and found a broken spring in the old FPR.
But is the frame rail tank switch/selector (front/rear) gone bad, or stuck? I'm thinking the diesel siphoned through the FPR and returned to the front tank. I'm in Alaska and the truck is parked in a gradge at night about 65 degrees. the tank selector would be on the front tank at night when this fuel tranfers to the front tank from the rear tank.
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums You would probably be better posting your problem on this page. I would bet there are guys there that have had that problem.
Good luck.
Good luck.
jb10725
10-14-2014 08:05 PM
DougJ_1997PSD
06-11-2014 05:56 PM
eatont9999
09-18-2011 06:42 PM
gracjm
05-21-2007 03:38 PM
