diesel in radiator powerstroke
It's got to be injector cups, it's the only place #2 and coolant pass. And the fuel system runs at a much higer psi than the cooling system so it will overtake it and fill into the coolant.
A head would have to crack all the way from the fuel passage to the coolant passsage and I don't think that's very likely.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
on
is there a way to test for witch one or side. yes it,s puring out the rad drain hole.where can i find the video? i drained to chech for clogged heater core have not had heat for 6 months.rad is about 1 year old,new thermastic.I STARTED TO GET ALL WATER OUT TO REFILL WITH NEW ANTIFREEZE.
psn Video Links
They are just okay IMHO
How to put the orings on the injectors
http://www.youtube.com/v/64pom10RCwg&hl=en&fs=1
How to put the injectors back
Engine Pull :: Injector Install video by MazdaMartinb4k - Photobucket
How to purge excess oil from the cylinders after installing the injectors by marty.
Injectors :: Purging cylinders video by MazdaMartinb4k - Photobucket
Try this one:
Damn leaking fuel injector cup R&R project
Another:
http://www.thedieselstop.com/forums/...urprise-58500/
Another:
on
Yep that works too. Pretty much for me if I have one that is leaking I am going to do them all anyway. or at least on bank. The only reason we have done them that way is we don't have the tools to R+R the cups and diagnose the issue and tell Ford what to fix. One of these days I need to build those tools. I am sure I will need them.....
Thing is the job is much worse in van body types.
Its the install of the cup that is the real pita.
I refuse to pull a head or motor for a cup replacement as i have seen
others do.
Bill
