diesel in radiator powerstroke
I HAVE A 95 F 350 7.3 TURBO , I DRAINED RAD. STARTED DIESEL COMES OUT THE DRAIN HOLE OF RADIATOR. WHAT COULD CAUSE THIS?
injector orings i would think
I really doubt injector o rings. Or the injector cups if it's getting into the radiator.
Are you sure its diesel coming out of it? I've only seen that once and it was a cracked head. |
why did you drain rad. to service or running hot
Cracked inj cup or head.
Bill |
yeah im also going to go with injecctor cup, theres a special tool, a guy made one on PSN and hes selling it for decent money too. real easy to do form watching the video!
Had this on my buddys 2002 ...replaced Injector cups...fixed
is there a way to test for witch one or side. yes it,s puring out the rad drain hole.where can i find the video? i drained to chech for clogged heater core have not had heat for 6 months.rad is about 1 year old,new thermastic.I STARTED TO GET ALL WATER OUT TO REFILL WITH NEW ANTIFREEZE.
It's got to be injector cups, it's the only place #2 and coolant pass. And the fuel system runs at a much higer psi than the cooling system so it will overtake it and fill into the coolant.
A head would have to crack all the way from the fuel passage to the coolant passsage and I don't think that's very likely. |
Originally Posted by raidergeo
(Post 8309315)
psn Video Links
Originally Posted by rideracelivemx7
(Post 8307744)
They are just okay IMHO How to put the orings on the injectors http://www.youtube.com/v/64pom10RCwg&hl=en&fs=1 How to put the injectors back Engine Pull :: Injector Install video by MazdaMartinb4k - Photobucket How to purge excess oil from the cylinders after installing the injectors by marty. Injectors :: Purging cylinders video by MazdaMartinb4k - Photobucket |
Try this one:
Damn leaking fuel injector cup R&R project Another: http://www.thedieselstop.com/forums/...urprise-58500/ |
Tj
We just pull the inj's and pressurize the cooling system. Bill |
Originally Posted by MADVAN
(Post 8314315)
Tj
Originally Posted by tjbeggs
(Post 8314346)
Yep that works too. Pretty much for me if I have one that is leaking I am going to do them all anyway. or at least on bank. The only reason we have done them that way is we don't have the tools to R+R the cups and diagnose the issue and tell Ford what to fix. One of these days I need to build those tools. I am sure I will need them.....
Thing is the job is much worse in van body types. Its the install of the cup that is the real pita. I refuse to pull a head or motor for a cup replacement as i have seen others do. Bill |
