6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Air Filter/breather thumping when cold
Old 04-02-2010, 08:12 AM
forddieseldoc's Avatar
forddieseldoc
forddieseldoc is offline
you might want check the air filter, their was a message about snow that becomes packed into the air cleaner. if this has happend it could have damaged the filter. they make a deflector to install in the housing, and if you plow snow you should use a winter grill. this will prevent it from happening again.
Old 04-02-2010, 10:02 AM
Jake4809's Avatar
Jake4809
Jake4809 is offline
The noise in my 08 seems to occur only when the A/C is on. Might be the compressor engagement thump forddieseldoc mentioned. Thanks
Old 04-14-2013, 07:57 PM
GHeTTo JOe's Avatar
GHeTTo JOe
GHeTTo JOe is offline
ive got the compressor clunk when it engages, and have read into it some but not much talk about it other than the tsb.
my question is this hard on the truck to not fix, is it just the sound that is the problem or will it take out the tensioner or compressor if let be?
Old 05-01-2013, 08:39 PM
forddieseldoc
I don't think that it will hurt the drive belt, tensioner or compressor. I have not seen many a/c system failures. I think it's the freon flow through the accumulator when the compressor engages. Not sure on that though.
Old 05-02-2013, 04:02 AM
fordtruggy's Avatar
fordtruggy
fordtruggy is offline
Blend door actuator? I think every single one ford made for 08-10+ is bad and will start clicking. Mine does. Gues that's more of a clicking then thumping...
Old 05-02-2013, 05:00 AM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
More like a typewriter behind the dash.
Old 05-02-2013, 10:36 AM
parkland's Avatar
parkland
parkland is offline
Originally Posted by ronnie jr
i just fixed a 2006 f250 with the same noise it was a broker roker on #8 exaust
These guys are speaking of a "thump"...
The rockers make a tapping or knocking noise when worn out or damaged.
What did that cost you, and did you do all of them, or just the #8 cylinder?
koboss1
12-08-2010 01:37 PM
iron1951
28
09-16-2010 06:47 PM
koboss1
05-11-2010 09:23 PM
koboss1
15
12-18-2009 08:42 PM
koboss1
03-20-2009 07:07 PM
Quick Reply: Air Filter/breather thumping when cold
