Crankcase under vacuum producing whirring sound until dipstick is removed?
Engine makes a whirring or whistling sound until the dipstick is removed then the sound stops. No driveability issues. Can't pinpoint problem using a mechanics stethoscope. When I removed the dipstick I put my finger tip on the tube and it was sucked onto the tube meaning the crankcase is under vacuum. I know this is backwards. How could I have a vacuum in my crankcase instead of positive pressure? Where should I start looing for this problem. I have never heard of negative crankcase pressure. This doesn't make sense. This is a 2002 5.4
the PVC valve in the right had valve cover is suppose to pull a slight vacuum on the crankcase to pull out fumes and burn the vapors... if the valve failes you could get excessive sucking... Thats the only thing that causes crankcase vacuum, otherwise it would be positive pressure from piston leakby.
After having thought about this a little more I know I have positive crankcase pressure due to blowby which is then turned into negative pressure by engine vacuum through the PCV valve. The thing is I haven't seen a vacuum strong enough to hold my finger against the dipstick tube. So when I put the dipstick back in and the whistling sound comes back the vacuum is still there and it's bleeding past a seal creating this sound? Are we talking about the front or rear crankcase seal, valley cover seal or rocker cover seal?
eallanboggs
2004 - 2008 F150
12-20-2021 06:09 PM
donerico
15
04-06-2017 04:09 PM
bb65f1004x4
08-17-2015 12:14 PM
95ford250_460
01-11-2005 03:35 AM
