Another engine question
sorry about all the questions guys I am still new to the BBF. Looking for a BBF to go into my 77 F-250. what would a 429 out of a LTD w 60,000 miles be worth to buy the complete motor? casting #'s C9VE-A for the heads and C9VE-B for the block. How much would you say it is worth? thanks for the help guys.
Sounds like a good $500 motor. Nothing special about the heads or block.
However, be advised that the arrangement of the accessories (alternator, A/C etc) may not allow it to fit into the truck engine compartment.
The car layout tended to be low and wide, whereas the truck arrangements tend to be high and narrow.
The A/C compressor and/or the alternator may end up on the frame.
Also you will need the Ford 460 perches to mount it correctly.
Good luck on this project, you will like the 429.
Those CRs sound pretty high for a Lincoln.
My knowledge of performance capability is very limited, but I would hesitate to think that Ford believed grandma and grandpa expected high compression engine performance in their luxury car. They wanted accessories and comfort, not horsepower - but that is my opinion.
Hopefully someone with better knowledge than I can assist you with better specs.
just because it has c9ve on the block doesnt mean its a 429 it could be a 460
I bought a c9ve motor not maybe a week ago along with a d0ve block and both had 460's in them
the heads are good though they are around 72-74cc's and on the stock 460 psiton would net you around 10:1 on the 429 11:1 so 93 octane would be fine just don't get it to hot or to much timing
when you want to have some fun put the timing up to around 35 at full advance and a lil 104 and it will really wake it up
Fits: 1958/59 332 / 1958/67 352 / 1961/76 390 / 1962/63 406 / 1963/68 427 / 1966/70 428 / 1968/71 429 / 1968/76 360.
First year for the 460 w/a manual transmission: 1983.
460: 1968/71 Lincoln/Mark III only / 1972 Lincoln/Mark IV & 1972 Thunderbird / 1973/78 Ford/Mercury/Lincoln Passenger Cars / 1973/79 F100/350 / 1975/96 Econoline / 1983/97 F250/350.
429: 1968/73 Ford/Mercury Passenger Cars.
Decimal conversion chart in the front of the catalog sez: 43/64" = .672" ~ 17.066mm // 27/32" = .844" ~ 21.431mm // 1" = 1.000" ~ 25.400mm
