where kickdown lever attaches on tranny
The only F Series trucks to use an FMX were 1973/77 F350's with the 300 I-6.
If the trans was swapped, the original kickdown rod from the 1974 F100 may not work, as its configuration may be different.
1974 as original: If the truck has a 240/300 I-6 or a 302, the A/T is a C4 (11 trans pan bolt holes). If a 360/390/460, the A/T is a C6 (17 trans pan bolt holes).
The FMX has 14 trans bolt holes.
FMX
A little clairification for us the ignorant--the fmx is the tranny kickdown?
I have a 79 F150 with a 400, motorcraft carb and what I thought was a tranny kickdown (the part that looks like and is mounted like the Ford manual picture for the 460 and 390)
From what I am gathering either the piece in question is not a tranny kickdown or it is some kind of aftermarket/custom add on.
Is this correct?
Thank you
Is this correct?
Thank you
Is this correct?
Thank you
Is this correct?
Thank you
The transmission kickdown (basic p/n 7A187) is the rod that goes from the carburetor to the transmission.
Before electronic controls this is how the transmission knew when the throttle was floored and to kickdown into a lower gear.
It is attatched to an arm on the throttle shaft of the carburetor and the other end hooks to one of the two arms that comes out of the transmission, the other arm is the gear selector and goes to the gearshift.
Since the OP failed to mention the engine size. 1974 F100: Here's all the kickdown linkage and etc that applies.
Illustration Section 97, Page 7 (I-6) / Page 8 - 302 (upper pic) 460 - (lower pic) / Page 12 - 360/390 (lower pic).
Thank you
Thank you gentlemen,
The linkage is exactly the same on mine (even though it is the 400) so we are on the same page.
To avoid starting a new thread for a very similar question, on my 78 with the, motorcraft carb, there is a part that looks like a big short fat sparkplug sitting directly in front of the end of the gas pedal linkage. Coming out of the end of this thing is a wire.
I can't see this mystery part in the provided diagrams.
Any ideas?
Any ideas?
jdgarner13
05-21-2017 02:56 PM
83f150xlt
02-01-2017 01:38 PM
Building_Fords
09-05-2016 09:24 PM
94-Beast-F350
01-01-2016 09:41 AM
tractoman
03-23-2006 12:14 PM
