Mounting stuff on transmission hump
So I need to put a console between the bench seat & dash of an 92 F-350 & a 96 F-150 to hold radios, switchbox, & such. My question is if I mount it with self tapping screws do I have to worry about hitting something when I screw into the truck? Should I avoid using certain size screws? Should I avoid screwing into particular places?
Thanks in advance!
Thanks in advance!
When drilling through carpet, I use a nail clamped in a pair of vice-grips, heated to red hot with torch or gas stove top to "melt" a pilot hole. Most folks will tell you to use a utility knife & make an "X". I find that leaves a ragged edge & can still cause a "run" in the carpet if the bit or screw grabs a thread.
FARM69
03-22-2006 10:08 PM
63Fairlane500
12-07-2003 01:06 AM
