1978 - 1996 Big Bronco
Cleaning my Engine?
Old Apr 12, 2013 | 11:37 AM
Built-Ford-Tough91's Avatar
Built-Ford-Tough91
Cleaning my Engine?
I recently took my bronco muddin and the engine bay is really dirty. I don't want to screw anything up because all my wires are exposed as well as the distributor cap. So, I'm planning on washing the engine but I was wondering what would you recommend for cleaning it out? and what precautions should I take to avoid messing anything up?
Old Apr 12, 2013 | 01:17 PM
b4hntn's Avatar
b4hntn
I would not touch it.
Old Apr 12, 2013 | 09:27 PM
93'Bronco's Avatar
93'Bronco
I purple powered and pressure washed and it never hurt anything but maybe I got lucky
Old Apr 15, 2013 | 12:13 AM
greystreak92's Avatar
greystreak92
There are a lot of electrical connections under the hood and soaking them could present issues however, these connectors are made with tight fitting parts and the critical ones are pre-sealed with dielectric grease to keep moisture out. The biggest concerns are actually the most obvious ones. The alternator, the ignition coil, the distributor and the small bank of little electronic devices mounted near the coil should be covered to prevent water damage. Water is insidious so don't risk it. I use freezer bags and electrical tape to seal up any devices and connections that might get waterlogged during cleaning.
The other option is to simply wipe down the engine bay with wet rags. Its tedious and painstaking if you are a perfectionist like I tend to be but it saves the time of sealing up all the devices that don't play well with copious amounts of water.
Old Apr 15, 2013 | 11:03 AM
Built-Ford-Tough91
Sounds good! I think I'll stick with wiping it down with a damp rag
Old Apr 15, 2013 | 12:43 PM
Encho's Avatar
Encho
The Southernmost Mod
Your can use water to wash the engine bay, but don't use full pressure, a couple of plastic bags covering the alternator and the distributor should be enough. If you use a pressure washer open the spray and keep the tip of the washer a safe distance appart from any parts of the engine, try to avoid any cables, fittings and vacuum lines.
evan_nugget
General Automotive Discussion
Feb 28, 2018 05:21 PM
landers0440
Jun 1, 2014 09:08 PM
F350idiford
Apr 12, 2012 03:14 PM
ctboyle03
1983 - 2012 Ranger & B-Series
Jan 21, 2007 07:40 PM
krol
Offroad & 4x4
75
Feb 21, 2005 08:58 PM
