question have the internal clutch slaves
question have the internal clutch slaves. if they arent adjusted right will they leak? i just replaced all parts of the clutch system.. and it is bleeding out at night espelly when it is colder out. can help??? and my trans. doesnt have a inpection plug. it has never been cut out.. i thought about cutting it myself.
No, it would not--UNLESS, (possibly?) it's leaking fluid onto the friction disc.... But no, in and of itself, a leaking slave cylinder will NOT cause the clutch to slip, because the slave DISENGAGES the clutch. When the slave fails, it fails to disengage the clutch, i.e., it FAILS to make it slip.
Big Six
Big Six
Please see the bolded line in my quote, below, taken from my response, immediately above your last post. IOW, I already acknowledged the possibility that brake fluid is making the OP's clutch slip.
Big Six
Big Six
Originally Posted by andym
What if the slave sort-of fails to disengage the clutch? It could slip more.
No slave cylinder action = no disengagement.
Partial slave cylinder action = partial disengagement, UNTIL the clutch pedal is released, then full engagement returns, due to the pressure plate springs.
So how does a slave cylinder that "sort-of fails to disengage the clutch" cause it to "slip more"?
BigSix1
However, this line of yours, below, is not comprehensible to me:
Pkupman82
12-09-2010 10:28 PM
grizbait
01-28-2009 01:37 PM
hillbilly delux
06-12-2007 08:40 PM
pzvt
11-03-2005 09:19 AM
