carb choice ford bb
ABTW he didn't say it was too big, he said it was almost too big. I'm not having any problems - except maybe with mileage - performance is outstanding. After two cars with quadrajets, I'm big on Carters anyway.
Julie (or anybody else), I have very little knowledge of carburetors, but I've always been curious about how to size them for any specific combination of CID, cam, etc. on a given motor. Have you had any issues with idling with your setup? For example, if you put it in gear and hold the brakes while letting the clutch grab just a little, do you find the engine starts to misfire?
The reason I ask is that, when I was a little bugger (we did our homework with chisels and stone slabs in those days ), I used to hang out at a tiny local garage that built the car Dan Caroll (sp?) drove on the NASCAR circuit. They had the usual big engine in there (don't remember the CID) and I believe a 1350 cfm Holley on top. The thing wouldn't idle below about 1000 RPM. Even at 1000 RPM, it was having a hard time drawing enough air through the carb to get some vacuum and pull gas through the fuel channels.
There are general guidelines for carb cfm vs CID, but it's definitely affected by the total combination. Flow cababilities of the heads and intake. Camshaft specs, rear engine gear ratio, vehicle weight etc. A spreadbore carb will allow you to run a large cfm carb with small carb characteristics at idle and cruise. Quadrajet is a good example of that. It is about almost 800cfm and GM put them on 305 CI engines for a decade.
A 650 cfm is a good street size for a 390 IMO, but a properly tuned 750 would also be fine.
Speaking from personal experience w/ my 85 Bronco, 351w factory 4 bl intake and no performance mods. Bought the truck w/ the leaking Motorcraft {factoryholley?} carb, never could get it to run right. Replaced w/ a new electric choke 650 Holley. Hard to set-up correctly, always needed re-tuned every time the weather changed but was hands down the best performer running WOT. Last mod before selling the truck, mild RV cam new 650 Carter AFB and an Edelbrock performer intake. Starting, running, fuel economy, and overall drive-ability, as well as no leaks, vacuum or fuel, and as far as set it and forget it, was perfect. If there was a one-barrel version of that carb for my flathead I'd be all over it !
Howdy,
I would also suggest a 650.
I have one that I was going to put on my 292 but I'm being told it's a little "big" too!
It was on my OMC King Cobra 460. I Completely rebuilt it before removing and replacing the engine.
It's a 650 cfm Holley. It's what I would put on your engine.
If you want it, PM me.
Cheers,
Rick
Cheers,
Rick
SaltedTrucker
06-17-2015 11:22 PM
Rebel 84
05-17-2015 07:06 AM
frenchyo
04-29-2015 12:11 PM
Jtay561
02-19-2015 02:40 PM
Bigfatsteve
04-18-2014 10:42 PM
