Weatherstripping
Old Dec 14, 2009 | 01:58 AM
Tumblindyce's Avatar
Tumblindyce
Weatherstripping
Anyone have any opinions/experience with who makes the best weatherstripping for doors? Thanks...
Old Dec 14, 2009 | 05:14 AM
Lakotas53's Avatar
Lakotas53
I haven't reached that point in my rebuild yet. But have seen many threads on that very subject. Do a search for weather stripping and I am sure you will find all the answers you need to make the correct choice. Lakota
Old Dec 14, 2009 | 09:12 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Here's some reading that ought to answer all your qeustions
https://www.ford-trucks.com/forums/6...her-strip.html
Enjoy the ride
Bobby
Old Dec 14, 2009 | 09:46 AM
cbass139's Avatar
cbass139
I can tell you that LMC does not and when I researched mine, after buying the crappy ones, I found that everybody was saying the Dennis Carpenter ones are the best. He actually makes them, has the molds and they fit the way they are supposed to. Good luck.
Old Dec 14, 2009 | 12:28 PM
Tumblindyce
Bobby,
Thanks for the link...informative stuff and an entertaining discussion of the search function as well. Thouhgt I'd share an idea here, it's something that we use at work when we want something to be held in place until the glue dries: 2-way tape--you can get this stuff very thin and it really sticks well. Place some of it between spots or lines of whatever adhesive you're using. It might be helpful in getting the weatherstripping fit right as you would be able to stick one spot and then move on to the next without the previous spot moving around on you (I'd do a mock up first). Polyuerethane hot glue also works wonders for keeping things in place until the permanent adhesive has time to set up. By using one of these methods to keep things where you want them, you keep from making a major mess...just my 2 cents...
Old Dec 14, 2009 | 04:21 PM
rdemilt's Avatar
rdemilt
When I purchased my truck it had new rubber and both door stuck out like flaps on a airplane plus 2 broken side windows. The PO told me his wife was determined to get the door shut tight so she slammed them with enough force to brake both windows on the same day . I did some bodywork here and there then purchased the hollow weatherstrip from Mid-Fifty. the doors are now adjustable and shut as new.
GeneGregory
Sep 6, 2015 05:34 PM
84-250
Jun 13, 2015 07:49 PM
Castleville
Sep 2, 2014 12:00 PM
John R. Thomas
Jul 29, 2013 07:47 PM
crestfallinman
Mar 29, 2012 09:53 PM
