Adding dual tanks
Old 12-07-2009, 08:07 PM
currituckF150's Avatar
currituckF150
currituckF150 is offline
Adding dual tanks
Is it possible to add dual tanks to a truck w/ just 1 tank. What I'm mainly refering to is the electrical connections under & in the cab. I have a truck w/ dual tanks so I have all the parts I need(tanks, straps, fuel lines, dash switch, bedside, etc.) Is the electrical stuff ran from factory & just not used? Or am I going to have to add everything? Thanks.
Old 12-07-2009, 08:53 PM
Volvo92906's Avatar
Volvo92906
Volvo92906 is offline
Anything is possible. If you already have the parts you know you need to mount up a selector valve and run the new lines and wires for the pumps. As for the trucks coming with the connections factory im thinking no, but I have been told they made one harness to make things easier. Maybe someone else knows for sure. But, it is possible.
Old 12-07-2009, 10:32 PM
subford's Avatar
subford
subford is offline
The wiring inside the cab should be there, just unplug the selector jumper and plug your selector switch in place of it.
You will have to run the wires from the under hood dash to the tanks however.
It looks like you are working on 1990 or newer trucks so you will not use a selector valve.
Old 12-08-2009, 07:05 AM
currituckF150
Thanks, Bill. I think I know what you mean but I need to make sure. You said under hood dash, I'm thinking the underhood power dist panel, right? & since the wiring for the rear tank is there already, I would just have to run the wiring for the front tank, correct? Is the wiring for the tanks A plug & play from end to end? I could just take it out of my parts truck if that is the case.
Old 12-08-2009, 07:24 AM
subford's Avatar
subford
subford is offline
No I mean the firewall plug that has the cab wiring on the other side and the wires from the plug run to the fame and to the back of the truck.
These two wire may already be there and the plug for the front tank may be taped to the harness near the where the tanks mounts. So I am not 100% sure if the wire are there or not under on the frame but would think not.
Yes if they not there you will have to run them from the firewall plug to the tank.
Yes if you take the frame harness from one truck and put it on the other.
By the way what year trucks are we working with?
Old 12-08-2009, 07:33 AM
currituckF150
The truck w/ single tank is the 93 F150 XL 4x4, my parts truck is my totalled 95 Lightning.
Old 12-08-2009, 07:48 AM
subford's Avatar
subford
subford is offline
The frame wiring harness I am talking about is the C205 wiring harness.
C205 is the firewall plug.
Old 12-08-2009, 07:55 AM
BigBlueOx's Avatar
BigBlueOx
BigBlueOx is offline
Is the '93 a short bed? If so you may want to measure the front tank legnth. I'm pretty sure they didn't install the front tank on 4x4 short bed reg cab because of transfer case/gas tank clearance issues. Just saying. Good luck.
Old 12-08-2009, 08:02 AM
currituckF150
Thanks, Bill. As always, you are a wealth of info.
Yep, it's a shortbed. The thought never crossed my mind! Thanks, Big, I'll check it out at lunch.
Old 12-08-2009, 10:49 AM
BCHauler's Avatar
BCHauler
BCHauler is offline
x2. I've read previous threads about this.
Ninra
10-06-2013 08:52 PM
Franken-Truck
Electrical Systems/Wiring
12-18-2011 06:20 PM
BadgerF250
19
06-12-2011 09:03 AM
wifes65
07-24-2008 05:39 PM
skunked
04-02-2007 02:27 PM
Quick Reply: Adding dual tanks
