Where to find a Power steering pulley
Old 11-29-2009, 10:47 PM
pedrorairez's Avatar
pedrorairez
pedrorairez is offline
Hello everybody Looking for a Power steering Pulley for a 1975 Ford F150 A/T 360 2wd I was replacing my power steering pump and at the time didn't have a pulley puller so I was trying to remove it with another type of puller and that didn't go well I damage the pulley and now its bent I put in the pump and that doesn't leak anymore but now the belt doesn't stay on because the pulley is bent other than going to the junkyard is there any autopart store that stock these pulley's.
Old 11-30-2009, 07:25 AM
dhobdey1's Avatar
dhobdey1
dhobdey1 is offline
You can try Schucks, or Autozone, but I like NAPA, good Luck
Old 12-01-2009, 09:09 PM
steponit's Avatar
steponit
steponit is offline
Buy a $10.00 PS puller from Harbour freight and get one off a 70's Ford card at the wrecker's
should be the same
Old 12-04-2009, 01:19 AM
Greywolfnsl's Avatar
Greywolfnsl
Greywolfnsl is offline
Autozone has the rental program if you don't want to buy it, but i love tools to much so i bought it and had the pulley off in just a couple of mins. You might be a little frustated after how easy that tool makes it cause i did the same thing. haha but definaltly worth getting that tool.
Old 12-04-2009, 03:49 AM
460/5's Avatar
460/5
460/5 is offline
Zombie Survivalist
did the same thing with my 76. took 10 minutes to set everything up and get it off the old pump. put it on the new pump using a rubber mallet as close to the center as possible. my suggestion for once its on the shaft, use a peice of pipe between the mallet and pulley that will go over the shaft to apply even pressure while you tap it back on.
Drlittle
06-05-2017 11:34 PM
3fidty1
1978 - 1996 Big Bronco
04-17-2017 05:34 PM
mxer0022
09-13-2016 09:58 PM
geoffstevens79
Aerostar
07-09-2016 07:06 PM
henryfrick
05-22-2016 05:26 PM
Quick Reply: Where to find a Power steering pulley
