Check engine warning light comes on.
I have a 94 F350 diesel and when I first start the truck up and within a minute the Check Engine warning light comes on and the truck runs really rough with no power. In about 2-3 minutes the Check Engine light will go off and the truck runs normal again. If I turn the engine off and start it up again the same thing happens.
The manual states when the light comes on when the Electronic Engine Control System (EEC) is not working correctly and if it comes on ans stays on when driving have vehicle serviced but do not need it towed. (does this mean it should not lose power? Sure is not drivable when this is happening now.)
If it is the EEC where is it located on the truck and is it easy to replace?
Thanks
Marty
Thanks
Marty
It's probably not the EEC for a 94 unless it's a very late 94 making it one of the early Power Strokes.
You're in the wrong forum in either case.
Try posting your question in the 7.3L Power Stroke forum.
Cheers,
Rick
Cheers,
Rick
HD
13
01-09-2016 07:05 AM
msp252
1997-2006 Expedition & Navigator
18
12-13-2015 12:56 PM
cdavidwright1
03-22-2008 05:24 PM
