Glow Plugs
Glow Plugs
Just changed mine out with the much appreciated help of ponyboychris (Chris) help. The job was not that bad, the hardest part was getting the darn valve covers off! Come tomorrow morning I will see if it helps the cold start issue I have been having. Once again I would like to say thanks to Chris for the help and if anyone can rep him, please do! While I was in there I also re-torqued the injector hold down bolts and rocker arms.
Don't use anything but Motorcraft.
Congrats Andrew. I'll keep my eyes open for Chris.
How much do you know about the process? Tube to unscrew them. Take socket off after broke loose. Re-torque rocker arm pedestals & injector hold down bolts. Inspect and maybe shim the UVCH. Any of that make sense, or are you needing more detail?
Stay away from Autolite glow plugs.
All good advice from the people above. I would say with one person it can talk 5+ hours, but with two you can almost cut that time in half. Definitely get Motorcraft if you can. A small tube or good needle nose pliers help get them out. Just make sure the wires aren't rubbing on the rocker arms and are securely plugged into the new glow plugs.
Um... They should only be about half that Your shopping at the wrong place, LOL.
The whole process isn't that bad. I wish I was a little taller though. reaching in, over and around the engine compartment can be a pain. A small tube that grips the GP is a must, I had a couple of them that I had a hard time getting out because of oily fingers and tools. Like Andrew said, not a bad job but can be a pain to get the valve covers off and all the other stuff removed to get to them.
Night and Day! I wish I would have changed them last year! The truck does start faster but has and extremely smooth idle once started, so much better then what it did before. Thanks again buddy, and once you have all the pieces for your maintenance day, call me.
