Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2007 and Newer Expedition and Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
Is F-150 Still King?
  #1 (permalink)
Old 11-08-2009, 01:32 AM
wogdiml wogdiml is offline
wogdiml is starting off with a positive reputation.
Thule Box mounted on factory racks
I need advice from those that have mounted the Thule, Yakima or other luggage/cargo boxes on the factory rack crossbars. I have read from some others (not specific to Expeditions) that they recommend using thin foam between the box and the crossbar to eliminate knocking or vibrating and to use rubber tubing around the steel u-bolts to keep them from sliding or marking up the bottom of the crossbars. I have mounted my new Thule box in the garage to adjust the spacing of the crossbars and see how it installs and it seems very tight once everything is locked into place but I don't want to figure out different on a road trip beginning in a week. Thanks for the advice and suggestions.
  #2 (permalink)
Old 11-08-2009, 06:38 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
I like firm rubber between all the mounting surfaces. I don't have a thule box on my expy, but have had several similar items on previous vehicles.
  #3 (permalink)
Old 11-09-2009, 07:12 PM
07EXPYEL 07EXPYEL is offline
07EXPYEL is starting off with a positive reputation.
I've got about 7,000 miles with my Yakima SKYBOX21 and it fits nice and tight and doesn't vibrate on the factory cross bars.
  #4 (permalink)
Old 11-10-2009, 02:12 AM
david_jr david_jr is offline
david_jr is starting off with a positive reputation.
Quote:
Is this available at a hardware store or auto parts place?
  #5 (permalink)
Old 11-10-2009, 03:38 AM
cipduhop cipduhop is offline
cipduhop is starting off with a positive reputation.
I'm very interested! I would love to find out more inforamtion related to this topic. Thanks in advance.
me too, I need more detailed info.
__________________
Cheap tennis ball machine information and reviews of prince and tennis twist | Lobster tennis ball machine
  #6 (permalink)
Old 11-10-2009, 08:37 AM
For finding rubber, put your MacGyver hat on. . .
For round-ish tube I just find a thin wall rubber hose (like for a heater core) of the appropriate diameter and cut it open (forms a C) and then wrap it around whatever tube you need to protect.
Otherwise you can find flat rubber, even door weatherstripping. There are a variety or products that will work well.
  #7 (permalink)
Old 11-10-2009, 11:42 PM
Quote:
My Thule box also fits very tight once I get all 4 steel u-bolts clamped down, so I'm hoping it stays that way on the road because I'm down to the last day before the road trip and don't have time to look into a large enough piece of rubber between the box and the crossbar of the roof racks. I did put a thin walled rubber (pond liner - wrapped in electrical tape) around the u-bolts because I could get a little sideways movement with the box when the u-bolts were in metal-to-metal contact with the bottom of the crossbar. I'm hoping this provides a little bit more grip between the u-bolt and crossbar. I'll update once we return from the trip.
  #8 (permalink)
Old 11-11-2009, 10:39 AM
Quote:
The u-bolts are the main reason I purchased the Yakima Skybox, no tools to install or adjust. I've put this on 10 different vehicles and can make the adjustments is just a couple of minutes without tools. I rent my skybox out for $45 a week for a little extra money by advertising on the local craigslist.
  #9 (permalink)
Old 11-11-2009, 11:54 AM
How do the Yakima boxes install over factory racks? I think Thule has gone to a new system that replaces the steel u-bolts.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
