Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 03:19 PM
constrkings constrkings is offline
constrkings is starting off with a positive reputation.
6in lift with 38/15.5 ssr swampers and performace 5.4
Hi guys, I just retired my 03 f250 larit SD as my company work truck.
I am going to put it up and was looking into a icon 6 in lift. and cut out fender flare. I want to run 38 15.5 ssr swamper with this set up and was wondering if any one has done 38 with a 6 in lift. if they had rubbing isuses ,and what back spacing of wheel they used.I will be useing the truck for moderate to hardcore wheelin. Also, my truck is a 5.4 v8 with witch just spit out a spark plug. So i am replacing my heads with the trick flow twisted wedge heads for the 5.4. Adding a comp cams XE262AH cams pn#012500 and a HPS(high performce solutions)5.4 intake.And maby a voretech suppercharger in the future(over bugdet already lol).I will be runnig 5.13 gears with detroit lockers front and back.
I am currently running shorty headers with a custom 2 1/2 in pipes magniflow cats and flowmaster 40 series mufflers. Is any one runnig a set up like this do they like it ,and what kind of rwhp are they makeing. Does any one make full lenght headers for SD 5.4's Any coments would be great thanks.
  #2 (permalink)
Old 11-04-2009, 05:16 PM
Ian123 Ian123 is offline
Ian123 is starting off with a positive reputation.
i cant really answer any of those questions other than the lift...those tires will definately rub with a 6 inch lift. the 38s MIGHT fit but its the 15.50 width that will make them rub. an 8 inch lift would be a better choice. they might even still rub depending on rim backspacing but only on really sharp turns.
__________________
Quote:
Originally Posted by Kevin_350 View Post
I want to keep away from the new, highly emissioned 6.4L and 6.7L (coming out in 2011) diesel engines. I'm all for loud, whistling diesel engines and I'm 100% anti-green.
-Kev
  #3 (permalink)
Old 11-04-2009, 05:30 PM
suzuki0702's Avatar
suzuki0702 suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
i can honestly say i havent seen anyone on here running that kind of setup. im interested to see that thing running!! subscribed!
__________________
2004 F250 CrewCab, FX4 Off-road, 5.4, K&N FIPK, Jensen 7" TFT flipout touchscreen, Whelen Hideaway strobes, 1650 CCA dual batterys, 8' 6" western proplus
  #4 (permalink)
Old 11-04-2009, 06:09 PM
Most people run 37/13.5 with a 6 in lift. The 38 /15.5 are only 1 in taller and 2 in wider. I would like to stay with the 6 in lift for the lower center of gravity. This is why I was going to use the bushwacker cut out flares for the extra room. I am concerned with the witdth of the tires rubbing at full lock , full compresoin on the leaf springs. Thats way i need to play with the back spacing of the wheels. I'm not really concerned with the hight of the lift with the hight of the tire, espesially with cut out. If it does hit fender i will trim them till they dont. I will post some pic and a dyno sheet when i'm done.
  #5 (permalink)
Old 11-04-2009, 07:29 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian is gaining momentum as a positive member of FTE. Furian is gaining momentum as a positive member of FTE.
I'm looking at very similar mods for my 2005 F350. The Bushwacker "cut-out" flares will significantly reduce the amount of lift required to clear the 38" tires. There is a guy (Tank 250) that is running 41" Irok tires with only a 4.5" Icon lift kit on his 2006 F250. Therefore, you should have no issues with 38" tires with the 6" Icon list kit.
Here is a guy running a 2.5" leveling kit and 36" tires. He has plenty of clearance at the fender wells.
Here is a guy with 38" tires and a 6" ProComp lift kit:
Rigs...
As far as wheels, you will need as little back spacing as possible with those 15.5" wide tires to avoid rubbing the front leaf springs. There is a recent thread from a FTE member who has rubbing issues with his Excursion. He too want to run 15.5" tires in the future and a back spacing of 2.75" was recommended, which means custom wheels.
As for long-tube headers, I recommend the OBX headers on eBay. The are high quality but designed for the F150. I plan to try them for fitment in the near future.
99-03 Ford F-150 Triton 4.6L 5.4L V8 ALL , OBX Header:eBay Motors (item 150384571291 end time Nov-05-09 13:06:39 PST)
I can't wait to see your setup... please post pics!
__________________
Andrew
2005 F-350 4X4, Regular Cab Long Bed, XL Package, 5.4L 3V Engine, TorqShift®, 4.10 Limited Slip, K&N CAI Kit, SCT Livewire w/ Custom Tunes from 5 Star Tuning
  #6 (permalink)
Old 11-05-2009, 05:34 PM
Hi guys, Thanks for the advice. 41" irocks sound nice , but i will stick to the 38ssr for now.(if they look to small or if i have the room at full lock i might be selling some 38ssr 's) I will be using the OBX header ill let you know how they fit , thanks. I order the lift kit, heads, cams, and intake maniflod today and will be ordering the headers later. That brings me back to rims i was thinking of some stazwork custom double bead locks, a little pricey but nice.
I wont get the heads tilll 12/2 and i have to order rims but im on it so not long now guys. I can't wait thanks guys
  #7 (permalink)
Old 11-05-2009, 05:50 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
2004 Ford F-250
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
Sounds like an interesting project.... subscribed!
Tags
06 , 2005 , 350 , 38 , 54 , 6in , cab , f250 , ford , headers , icon , inch , lift , lifted , regular , superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
