Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-23-2009, 06:13 PM
MxDad567's Avatar
MxDad567 MxDad567 is offline
MxDad567 is starting off with a positive reputation.
Brighter Reverse Lights
I have an 08 F350 Dually. Does anyone make a brighter reverse light. My windows are tinted and at night backing into my driveway its a tad dark. I saw some lights on another dually that mounted on the fender flare but no idea where to get them or if they would help/
  #2 (permalink)
Old 10-23-2009, 09:05 PM
gasgrunt88's Avatar
gasgrunt88 gasgrunt88 is offline
2002 Ford F-250
gasgrunt88 is gaining momentum as a positive member of FTE. gasgrunt88 is gaining momentum as a positive member of FTE.
What about mounting a couple small lights under the rear bumper and wiring them into your reverse lights?
__________________
Chris PAA MEMBER #90
2002 F-250 7.3L 114,000+ K&N Intake w/6637 & Pete's cover, MBRP 4" Turbo back, JW VB, Zoodad, AutoMeter Ultralite Boost & Pyro, DP Tuner w/80e 120r, 140x, CCV mod, ITP OBA, AIH delete w/boost, HPX, Foil Delete... Mods purchased & waiting for install: Big Poppa's Loaner Turbo
"Black smoke don't mean its broke!"
  #3 (permalink)
Old 10-24-2009, 06:44 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
I like a small set of driving lights mounted under the rear bumper and a toggle switch to turn on. Not only handy for backing in the dark but also hooking up trailers, changing propane bottles and what ever else you need light for at that moment.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #4 (permalink)
Old 10-24-2009, 10:10 AM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
I agree with Chris and mistakenID. A small set of aux lights will work well. You can wire them with a relay and a switch so that they can be used automatically or manually also.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #5 (permalink)
Old 10-24-2009, 07:36 PM
MxDad567's Avatar
I was hoping to find something clean looking. I know I could mount lights back there but it's not really what I am looking for in looks.
  #6 (permalink)
Old 10-24-2009, 08:14 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is online now
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
Here are two threads about auxiliary reverse lights. The first one is a set is a set of stealth lights installed that are virtually invisible until turned on. The second has a variety of members' vehicles with different lights / mounting suggestions.
http://www.ford-trucks.com/forums/59...with-pics.html
http://www.ford-trucks.com/forums/80...se-lights.html
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #7 (permalink)
Old 10-24-2009, 11:54 PM
MxDad567's Avatar
thats what I am looking for I think these are the same light
  #8 (permalink)
Old 10-24-2009, 11:58 PM
Big J
2005 Ford F-250
Looks pretty darn close, if not the same. I would think you could mount them like the ones in the first link on the gray Harley SD. Since your truck sits lower than his, I would think they would be virtually impossible to see until they're on.
__________________
John
  #9 (permalink)
Old 10-25-2009, 12:14 AM
MxDad567's Avatar
I am going to check Auto ZOne tom. They are pretty small show I should be able to hide them well.
Thx
  #10 (permalink)
Old 10-25-2009, 12:31 AM
Big J
2005 Ford F-250
Sounds good....best of luck with it and post up some pics when you get them installed.
__________________
John
  #11 (permalink)
Old 10-28-2009, 10:44 AM
jstnromero's Avatar
jstnromero jstnromero is offline
2005 Ford F-150
jstnromero is starting off with a positive reputation.
there is always this as well
White Night Rear Lighting System, Truck SUV Reverse Lights
~jstnromero
__________________
2005 F150 XL 4.2L V6
2.5" Autospring Leveling Kit
Flowmaster 40 SIDO Exhaust Before Rear Tire
Airaid Filter and Shield, Bamachips Custom Tune
Arizona FTE Chapter Member
  #12 (permalink)
Old 10-28-2009, 09:48 PM
gearloose1 gearloose1 is offline
gearloose1 is starting off with a positive reputation.
Wireless backup cameras wired mounted on the license plate screws, with power from the back up light (or license plate light) is the way to go.
Less than $100 if you shop carefully.
  #13 (permalink)
Old 10-29-2009, 08:53 PM
drivembig's Avatar
drivembig drivembig is offline
drivembig is starting off with a positive reputation.
Better check State and Local laws. Some don't allow but up to a certain candlepower for rear facing lights........
  #14 (permalink)
Old 11-10-2009, 10:52 PM
jbawilliams jbawilliams is offline
jbawilliams is starting off with a positive reputation.
Doesn't one of the under tail gate LED light bars go white when you go in reverse? I thought I saw on that did, but I didnt have the $$$, and now I can't find it.
__________________
No trees were killed in the sending of this message. However, a large number of electrons were terribly inconvenienced.
99 F350 CC DRW LB AT 7.3L PSD; 6637 Mod;
  #15 (permalink)
Old 11-11-2009, 01:14 PM
jsimon724's Avatar
jsimon724 jsimon724 is offline
jsimon724 is starting off with a positive reputation.
Quote:
Recon makes one like you describe - red turn signals, stop lights, goes white in reverse. Looks pretty sweet.
__________________
Jim
'06 F250 6.0 PSD Crew Cab FX4
ARE contractor cap, SCT X3, Airaid intake,
Dieselsite Coolant Filter, '08 Console, High Idle Mod, Bilsteins, Recon clear mirror lights,
Edge Insight, 4" Magnaflow Turbo-back
Tags
2009 , custom , f250 , f350 , fender , lights , reverse , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
